CHARLIE C Posted April 7, 2020 Share Posted April 7, 2020 When riding ,usually on a light throttle in a 30mph limit , the engine dies for a split second then carries on normally. This can happen several times on a 30 minute run. If I disable the QS using the 10 second method,then the QS light goes out and the problem disappears. Enable the QS and the problem reappears. Anyway to solve this apart from buying another new unit ? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 7, 2020 Supporting Member Share Posted April 7, 2020 7 minutes ago, CHARLIE C said: When riding ,usually on a light throttle in a 30mph limit , the engine dies for a split second then carries on normally. This can happen several times on a 30 minute run. If I disable the QS using the 10 second method,then the QS light goes out and the problem disappears. Enable the QS and the problem reappears. Anyway to solve this apart from buying another new unit ? Any chance you are riding with you toe under the shift lever? When the QS detects lever movement, it very briefly cuts power. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
CHARLIE C Posted April 7, 2020 Author Share Posted April 7, 2020 Good idea , but no , that's not the reason .I've had the bike for 18 months and it's only just occurred. Up until a week ago it worked perfectly Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 7, 2020 Supporting Member Share Posted April 7, 2020 11 minutes ago, CHARLIE C said: Good idea , but no , that's not the reason .I've had the bike for 18 months and it's only just occurred. Up until a week ago it worked perfectly Do you have the Y.E.S. warranty or has yours expired? It sounds like its time for the mechanic to have a look at it. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
CHARLIE C Posted April 7, 2020 Author Share Posted April 7, 2020 You are right. Time to check my warranty .I bought it in September 2018 from a Yamaha dealer,I am the second owner . . I might just be inside the 2 years. Link to comment Share on other sites More sharing options...
Dodgy Knees Posted April 7, 2020 Share Posted April 7, 2020 I'm not gonna mention silent movies...anyway this issue has been discussed a few times and can be down to the slightest touch of your left boot. I hear what you say, but have you bought new boots.??? Link to comment Share on other sites More sharing options...
CHARLIE C Posted April 8, 2020 Author Share Posted April 8, 2020 Nope, same old Daytona's. Link to comment Share on other sites More sharing options...
HGP61 Posted April 8, 2020 Share Posted April 8, 2020 Could the shift lever pivot need cleaned and oiled maybe that the leaver isn't fully returning to the rest position. 1 Link to comment Share on other sites More sharing options...
CHARLIE C Posted April 8, 2020 Author Share Posted April 8, 2020 Good idea, definitely worth a try. Link to comment Share on other sites More sharing options...
CHARLIE C Posted April 26, 2020 Author Share Posted April 26, 2020 Unplugged the lead from the qs and the problem has gone away. The bike is still under 2year warranty and after emails to Yamaha and dealer they informed me of a 3month extension to warranty cover . So I am confident the qs unit will be replaced foc. Thanks to both. 1 Link to comment Share on other sites More sharing options...
