com3 Posted April 23, 2020 Share Posted April 23, 2020 APS part number for the 2015 FJ09 = 1MC-85884-00-00 TPS part number for the 2015 FJ09 = 13S-85885-00-00 my question is why are they different part numbers? it APPEARS as though they're the same part with different numbers... also, that same part looks to be the same part as the R6, R1, FJR, and all the 09 makes/models. can anyone verify this info? is the APS and TPS interchangable? thanks! Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted April 23, 2020 Supporting Member Share Posted April 23, 2020 (edited) 32 minutes ago, com3 said: is the APS and TPS interchangable? FWIW... the service manual shows ohm value to be different for each sensor, and measured across different set of terminals. Edited April 23, 2020 by piotrek 1 Link to comment Share on other sites More sharing options...
BBB Posted April 23, 2020 Share Posted April 23, 2020 They do different things as far as I know. This article is for cars, but the principal is the same. Accelerator Pedal Position Sensors vs. Throttle Position Sensors This article focuses on two types of automotive control units: the... 2 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
BBB Posted April 23, 2020 Share Posted April 23, 2020 The TPS seems to be shared across the whole MT 09 platform. The APS is also used on FJR1300 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
com3 Posted April 24, 2020 Author Share Posted April 24, 2020 Perfect! Thanks guys! Link to comment Share on other sites More sharing options...
