rodb47 Posted May 18, 2020 Share Posted May 18, 2020 Great thread. Going to switch back to the OEM plugs next service. 1 Link to comment Share on other sites More sharing options...
Premium Member fjray Posted October 18, 2020 Premium Member Share Posted October 18, 2020 On 4/27/2020 at 12:45 PM, piotrek said: I will get methodical with this once I have my ECU back... but the one constant appears to be ~7,000 RPM. It's either that or a particular throttle (grip and/or plate) position. More questions than answers at the moment. Are you sure it's not in B mode when this happens? IIRC, the B mode not only has less power, I think I read where it also has a lower redline than A or STD mode. Shocked me, but I don't worry about it by only using STD and A mode. Link to comment Share on other sites More sharing options...
littlebruv Posted October 18, 2020 Share Posted October 18, 2020 B mode is usually best for slippery or wet roads as it reduces the speed when trying to accelerate, especially away from junctions and traffic lights Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted October 19, 2020 Author Supporting Member Share Posted October 19, 2020 On 10/18/2020 at 10:57 AM, fjray said: Are you sure it's not in B mode when this happens? Yes Link to comment Share on other sites More sharing options...
duhs10 Posted October 20, 2020 Share Posted October 20, 2020 On 10/18/2020 at 10:57 AM, fjray said: Are you sure it's not in B mode when this happens? IIRC, the B mode not only has less power, I think I read where it also has a lower redline than A or STD mode. Shocked me, but I don't worry about it by only using STD and A mode. Unless that has changed... B mode is the same power and redline. Only difference is throttle mapping so that it takes more wrist to get the same amount of fueling. Another forum member and I tested this via numerous drag races on a closed course ;-). No matter the mode the result and speed was basically the same. This was with 2 '15 FJ-09's. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
