Premium Member fr8dog Posted May 19, 2020 Premium Member Share Posted May 19, 2020 In second gear at 25 mph mine runs a little rough. I've adjusted the APS and had the throttle bodies synched. I just figured it was the nature of this motor. 1 Link to comment Share on other sites More sharing options...
Wintersdark Posted May 19, 2020 Share Posted May 19, 2020 6 minutes ago, fr8dog said: In second gear at 25 mph mine runs a little rough. I've adjusted the APS and had the throttle bodies synched. I just figured it was the nature of this motor. It's not really fond of running at low RPM, which is basically required to ride slow. The TB's being out of sync makes it worse for sure, but it's not really happy at low speeds ever. I find you basically just want to use the clutch to smooth things out at really low speeds (which is generally what you do for low speed maneuvers anyways) 2 Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted May 19, 2020 Premium Member Share Posted May 19, 2020 14 minutes ago, Wintersdark said: It's not really fond of running at low RPM, which is basically required to ride slow. The TB's being out of sync makes it worse for sure, but it's not really happy at low speeds ever. I find you basically just want to use the clutch to smooth things out at really low speeds (which is generally what you do for low speed maneuvers anyways) I wasn't clear. I didn't get those things done because of how it ran at 25 mph. APS was done to smooth the abrupt throttle (it helped) and TBS was done when valves adjusted and plugs changed. I agree about the use of the clutch. Link to comment Share on other sites More sharing options...
bugie Posted May 19, 2020 Share Posted May 19, 2020 If you switch to b mode at those speeds you'll find it a lot less lurchy. A mode really doesn't like cruising at that speed Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted May 20, 2020 Premium Member Share Posted May 20, 2020 I'll try B mode. I'm in Standard all of the time. I know I'm probably in the minority. I've ridden in A and it's a blast. It's like a different bike. Link to comment Share on other sites More sharing options...
