Premium Member rustyshackles Posted May 31, 2020 Premium Member Share Posted May 31, 2020 Suggestions? I’m replacing tank grips. IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted May 31, 2020 Supporting Member Share Posted May 31, 2020 I cant really tell from the photo but is the actual top layer of the faux carbon coming up? For any adhesive I just use something like Goo Gone. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member rustyshackles Posted May 31, 2020 Author Premium Member Share Posted May 31, 2020 Thanks @betoney. As far as I can tell it’s adhesive not the finish peeling off, but I will pay close attention. IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted June 2, 2020 Premium Member Share Posted June 2, 2020 I'd test Goo Gone on the back side first, as it contains hydrocarbon solvents that can literally melt plastic. Goo Off is more friendly, or am I confusing the two? Probably am. If it uses Orange in the ingredients it may be ok but I'd still test first. I don't kerosene works well also and is safe on most plastic (and chain o-rings). 1 Link to comment Share on other sites More sharing options...
Johan Langworth Posted June 3, 2020 Share Posted June 3, 2020 I have not done bike decal removal, but for pretty much any residue left from regular stickers on a hard surface I use regular kitchen/cooking oil or olive oil. Just rub some in and then rinse with soap. It's a cheap solution atleast! 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted June 9, 2020 Supporting Member Share Posted June 9, 2020 (edited) I use WD40 to remove adhesive. Works great. It'll turn the glue to gel. Might take more than one application, but should soften it up enough to just wipe off. Bit of Simple Green or gentle detergent to clean off the residue, and you're done. Edited June 9, 2020 by knyte 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Premium Member rustyshackles Posted June 9, 2020 Author Premium Member Share Posted June 9, 2020 I used Goo Gone with a 10 minute setting period. All of the adhesive was removed, the bits of backing from old tank grip that remained rubbed off easily. IBA Member #59800 3 Nations Brewing Mug Club #100 Link to comment Share on other sites More sharing options...
