vancuy Posted May 20, 2022 Share Posted May 20, 2022 (edited) On 6/3/2020 at 12:37 PM, dazzler24 said: There has been a fair amount of discussion on this subject and a search will reveal more answers/suggestions but from someone who has actually done it and is the same height I can say this: - 1. Lowered my rear end by installing lowering links (Yamaha in my case but there are third party variants which offer lower height) 2. Dropped the front end a similar amount through the triple clamps to keep the geometry same/similar. 3. Got a lowered seat - again a search will reveal some options and prices. There are rear shocks that have the option to change their length which in turn directly affects the rear height. (I have a K-TECH Razor-R being one that offers this). I'll let you do a search for the price in your currency. These things do indeed lower the bike and allowed me to almost flat foot. As a couple of side effects of this lowering, in my experience, 1 - made the bike stand up a bit more on the side stand but not enough to worry me and 2 - the bike was a little harder to hoist up onto the centre stand. Some have reported that they scraped the belly/oil pan but I didn't have that experience and I'm sure factors such as terrain travelled over, your weight, suspension capabilities, etc would come into play in that department. Also, FWIW, I lowered mine for the same reasons you have stated but actually went back to standard height after my confidence became restored and I haven't looked back. I still have the seat on the lowest position though. Hope that helps. My bike = 2015 model. Hi Mate, I have the same bike and it was lowered when I purchased it. but my forks were not lowered. Can you send me a photo of front forks to see what it is like please? Edited May 20, 2022 by vancuy Link to comment Share on other sites More sharing options...
OZVFR Posted May 20, 2022 Share Posted May 20, 2022 The top of the stock forks are the same height as the top of the triple clamp, you just need to raise them 15mm above the triples. No problem at all when I did mine, but I’m only 72kg and have replaced all the suspension with quality gear to suit. 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 20, 2022 Supporting Member Share Posted May 20, 2022 2 hours ago, vancuy said: Hi Mate, I have the same bike and it was lowered when I purchased it. but my forks were not lowered. Can you send me a photo of front forks to see what it is like please? As I mentioned in that post, I've returned everything to the stock height since doing that but to address your question - when I installed the lowering links, I had the top of my forks (the gold bits) 10mm above the top triple clamp to 'equalise' the front and back height. So to be clear, I let the bike 'fall/drop' through the triple clamps by ~10mm. Hope that helps. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted May 20, 2022 Supporting Member Share Posted May 20, 2022 10 hours ago, vancuy said: I have the same bike and it was lowered when I purchased it. but my forks were not lowered. Can you send me a photo of front forks to see what it is like please? ...what @dazzler24 and @OZVFR are describing... 1 2 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 21, 2022 Supporting Member Share Posted May 21, 2022 8 hours ago, piotrek said: ...what @dazzler24 and @OZVFR are describing... Thanks piotrek. The old idiom of - A picture paints a thousand words - right there. 😁👍 1 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 21, 2022 Premium Member Share Posted May 21, 2022 For you vertically challenged, thicker insoles and hitting the gym are your easiest and healthiest options. Not my problem as in my yute* I was 6- 1 but being of early primate stock am cursed with incredibly long arms and torso but short inseam. I'm not complaining as my boarding house reach has kept me well nourished, and 32 inseam pants work well enough went seated though the rear hem drags when I shuffle about. Finding shirts with 37 sleeves, 18.5" neck and 36 waist was a joke, what I could find fit two of me. Not so much now days as neck has shrunk an inch and waist expanded but I digress. *One naturally shrinks as one ages due to creep deflection of spinal discs. Landing on your head 3 or 4 times doesn't help ones elevation either and also significantly dulls mental acuity. 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 22, 2022 Supporting Member Share Posted May 22, 2022 15 hours ago, 2and3cylinders said: Not my problem as in my yute* I was 6- 1 but being of early primate stock am cursed with incredibly long arms and torso but short inseam. I think I may have found a photo of you when you where in your primate prime. 😜 3 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted May 22, 2022 Premium Member Share Posted May 22, 2022 LOL Thanks but it's not me, as I always at least wore an open face helmet back in the day, and my hair was halfway down my back and very curly. When I yanked off my helmet I looked like a Brit magistrate whose wig was caught in a tornado. Plus my beard was much longer and also curly. And I'm a Dirty Blond. It could be a nefew of mine though. 2 Link to comment Share on other sites More sharing options...
vancuy Posted May 23, 2022 Share Posted May 23, 2022 On 5/21/2022 at 3:27 AM, piotrek said: ...what @dazzler24 and @OZVFR are describing... Thank heaps mate. Link to comment Share on other sites More sharing options...
vancuy Posted May 26, 2022 Share Posted May 26, 2022 On 5/20/2022 at 5:28 PM, OZVFR said: The top of the stock forks are the same height as the top of the triple clamp, you just need to raise them 15mm above the triples. No problem at all when I did mine, but I’m only 72kg and have replaced all the suspension with quality gear to suit. Thanks mate, I'll lower mine 15mm soon. 1 Link to comment Share on other sites More sharing options...
vancuy Posted May 26, 2022 Share Posted May 26, 2022 4 hours ago, vancuy said: Thanks mate, I'll lower mine 15mm soon. Will lowering front and rear effect the centre stand? Link to comment Share on other sites More sharing options...
OZVFR Posted May 26, 2022 Share Posted May 26, 2022 10 hours ago, vancuy said: Will lowering front and rear effect the centre stand? The bike sits a bit more upright, but it hasn’t been a problem. Toyed with the idea of shortening the side stand, but so far hasn’t been worth it 1 Link to comment Share on other sites More sharing options...
vancuy Posted May 29, 2022 Share Posted May 29, 2022 On 5/20/2022 at 7:23 PM, dazzler24 said: As I mentioned in that post, I've returned everything to the stock height since doing that but to address your question - when I installed the lowering links, I had the top of my forks (the gold bits) 10mm above the top triple clamp to 'equalise' the front and back height. So to be clear, I let the bike 'fall/drop' through the triple clamps by ~10mm. Hope that helps. Hi Dazzler, I lowered front forks by 10mm. I noticed a quite a difference when cornering. easier to countersteer. pushed it on a straight road until 150 kms/hr. very stable. Thanks for your advice. 2 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted May 29, 2022 Supporting Member Share Posted May 29, 2022 15 minutes ago, vancuy said: Hi Dazzler, I lowered front forks by 10mm. I noticed a quite a difference when cornering. easier to countersteer. pushed it on a straight road until 150 kms/hr. very stable. Thanks for your advice. I'm no expert but it would seem that in simple terms:- Drop the front end/raise the rear end and you have yourself a 'sport bike' that behaves like one. Drop the rear end/raise the front end and you have a 'cruiser/Harley' that behaves like one. Leave the suspension level (even if you drop/raise the front and back equally) on the Tracer and you'll have a 'Sport Tourer'. Look up Rake and Trail for motorbikes on the 'you tubes' or the 'interwebs' and you'll get some education on the subject like I did if you are interested. Many things to learn. Enjoy the ride either way 🙂 1 1 Link to comment Share on other sites More sharing options...
