Dodgy Knees Posted June 17, 2020 Share Posted June 17, 2020 Haha.. looks a lot worse than it is..but yes, good idea. 👍 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted June 18, 2020 Premium Member Share Posted June 18, 2020 17 hours ago, Dodgy Knees said: Haha.. looks a lot worse than it is..but yes, good idea. 👍 Ideally you should remove all the corrosion first, with either silicon-based sandpaper or aluminum oxide cloth. Do not use steel wool, brass wool, or any other dissimilar metal. Then paint it to prevent further corrosion. Just covering it with ACF or something will mostly (but not entirely) prevent further corrosion. Aluminum is prone to fatigue and cracking due to corrosion, in some regards even worse than steel. Link to comment Share on other sites More sharing options...
Wintersdark Posted June 19, 2020 Share Posted June 19, 2020 On 6/17/2020 at 2:54 PM, BBB said: @Dodgy Knees, some ACF50 on the alloy will help with that oxidation on your seat lock support. Fix it? Or just prevent it? Link to comment Share on other sites More sharing options...
BBB Posted June 19, 2020 Share Posted June 19, 2020 2 hours ago, Wintersdark said: Fix it? Or just prevent it? Both, allegedly. There are claims it fixes and prevents corrosion. Personally I’d do roughly as @keithu suggested, rub down with a scotchbrite pad, then smear on ACF50 with a cloth. ACF-50 Anti-Corrosion Supplier and Distributor ACF50 Distributor and Stockist Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Dodgy Knees Posted June 19, 2020 Share Posted June 19, 2020 Acf50 is brilliant stuff. When applied to metal, it will protect the finish for a long time, working like a barrier and also stop any corrosion getting worse. Also good on black plastic, deepens the colour if your dedicated rag is handy. I rubbed that bit with a rag and a little acf50 on afterwards, but it really wasn't much, looked bad in pic for some reason. 2 Link to comment Share on other sites More sharing options...
neOhJoe Posted June 26, 2020 Share Posted June 26, 2020 I believe that is to prevent the rubber plug from escaping. I have to take that off, then take the rubber plug with the arrow on it out to move the lever, to remove the front seat. Link to comment Share on other sites More sharing options...
Dodgy Knees Posted June 26, 2020 Share Posted June 26, 2020 My rubber plug went on holiday a long time ago. 🙂 Link to comment Share on other sites More sharing options...
Wintersdark Posted July 5, 2020 Share Posted July 5, 2020 On 6/26/2020 at 2:20 AM, Dodgy Knees said: My rubber plug went on holiday a long time ago. 🙂 Mine went in the trash the first time I adjusted my seat 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 5, 2020 Supporting Member Share Posted July 5, 2020 7 minutes ago, Wintersdark said: Mine went in the trash the first time I adjusted my seat Lol, mine too, other than being an inconvenience, I never saw the purpose of it. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
BBB Posted July 5, 2020 Share Posted July 5, 2020 9 hours ago, betoney said: Lol, mine too, other than being an inconvenience, I never saw the purpose of it. Allegedly, anti-theft, to stop the front seat from being removable without requiring the key in the rear seat. I tried it, out of curiosity and found I could get the front seat off, with the rear in place, if the rubber was absent. Quite what a thief would do then is where I get lost. 1 Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 5, 2020 Supporting Member Share Posted July 5, 2020 4 hours ago, BBB said: Allegedly, anti-theft, to stop the front seat from being removable without requiring the key in the rear seat. I tried it, out of curiosity and found I could get the front seat off, with the rear in place, if the rubber was absent. Quite what a thief would do then is where I get lost. Interesting. What exactly would a thief want under the seat?🤷♀️ ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
