Supporting Member texscottyd Posted June 24, 2020 Supporting Member Share Posted June 24, 2020 11 minutes ago, captainscarlet said: Looks like our standard chains have built in obsolescence! I view that as an economy reality of Yamaha manufacturing the bike to a specific price point. 10k - 15k miles from an OEM chain isn’t unreasonable, and you will be amazed at how much more substantial a good replacement chain feels... I put the DID VX on mine, and anticipate (hope? wish? pray??) for more longevity than I got with the factory chain. Link to comment Share on other sites More sharing options...
captainscarlet Posted June 24, 2020 Share Posted June 24, 2020 (edited) 36 minutes ago, texscottyd said: I put the DID VX on mine, and anticipate (hope? wish? pray??) for more longevity than I got with the factory chain. Indeed, according to D.I.D's own marketing blurb the VX and in particular the ZVM-X are supposed to last at least double the mileage. Time will tell.... CS Edited June 24, 2020 by captainscarlet 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 24, 2020 Supporting Member Share Posted June 24, 2020 1 hour ago, texscottyd said: I view that as an economy reality of Yamaha manufacturing the bike to a specific price point. 10k - 15k miles from an OEM chain isn’t unreasonable, and you will be amazed at how much more substantial a good replacement chain feels... I put the DID VX on mine, and anticipate (hope? wish? pray??) for more longevity than I got with the factory chain. It seems the VX has been replaced with the VX3. I recently ordered a VX and got the new VX3 from Sprocket Center. - "Superior longer life than previous D.I.D 525 VX chain models".👍 DID Chain 525 VX3 Pro-Street X'ring Chain - GOLD or NATURAL (choose length) - CHAINS <h4>D.I.D. Chain - 525 VX3 Pro-Street series X'ring Chain (Gold or Natural) -... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
nhchris Posted June 25, 2020 Share Posted June 25, 2020 (edited) So here is a photo of what I am seeing on my stock chain. I have three or four locations on the chain where this red dust is visible. (I first thought it was just a bit of rust.) Chain has 12,500 miles on it. @captainscarlet and @betoney, is this what you see and is it cause for immediate chain replacement? Thanks guys. Edited June 25, 2020 by nhchris 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 25, 2020 Supporting Member Share Posted June 25, 2020 @nhchris - yes but mine was quite a bit more than that. The biggest irritation though was the tight links, they made the ride very rough. I removed the wheel and went link by link moving them back and forth to try and free them up but that wasn't successful. Setting chain tension was impossible since on one section it was too tight and rotate the wheel a few inches and it was far too loose. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
nhchris Posted June 25, 2020 Share Posted June 25, 2020 Yep, my chain tension situation is exactly the same @betoney. In addition, I can hear rotational noise related to the drive train when riding without ear plugs. Sort of a "whrr whrr, whrr" that tracks with the speed of the bike. Faster speed more whrrs per minute! Unfortunately sprocket center is out of stock on damped 17-tooth front at this time. What chain do you guys recommend? And is it safe to use a clip link rather than a rivet master? I don't have a chain tool but would bring bike to shop for a riveting. 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
captainscarlet Posted June 25, 2020 Share Posted June 25, 2020 28 minutes ago, nhchris said: So here is a photo of what I am seeing on my stock chain. I have three or four locations on the chain where this red dust is visible. (I first thought it was just a bit of rust.) Chain has 12,500 miles on it. That is EXACTLY what I have been seeing on my chain and like you in a number of locations. Also the mileage correlates very well. I've done around 20 000 km which is give or take 12 500 miles. My understanding from reading elsewhere is that the dust is rust from inside the chain. Which means the inside of the rollers/links where the rust is coming from are shot. I am currently in the middle (literally, I've just undone the front sprocket) of changing my chain. Like you I have been experiencing noise and I'm sure more vibration than normal. I would not use a clip link, it is much safer to use a rivit. Also the front sprocket is a 16 tooth not 17 if you want to keep it standard. CS 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 25, 2020 Supporting Member Share Posted June 25, 2020 9 minutes ago, nhchris said: Yep, my chain tension situation is exactly the same @betoney. In addition, I can hear rotational noise related to the drive train when riding without ear plugs. Sort of a "whrr whrr, whrr" that tracks with the speed of the bike. Faster speed more whrrs per minute! Unfortunately sprocket center is out of stock on damped 17-tooth front at this time. What chain do you guys recommend? And is it safe to use a clip link rather than a rivet master? I don't have a chain tool but would bring bike to shop for a riveting. I posted a link for the DID VX3 chain right above. My last set of sprockets looked almost unused so I ran 2 chains before swapping sprockets I always use Superlite sprockets and always use a rivet master link. FJ-09 | Sprockets & Chain Kits Sprocket Center is dedicated to being the world's premium provider of... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
BBB Posted June 25, 2020 Share Posted June 25, 2020 2 hours ago, nhchris said: Unfortunately sprocket center is out of stock on damped 17-tooth front at this time. What chain do you guys recommend? And is it safe to use a clip link rather than a rivet master? I don't have a chain tool but would bring bike to shop for a riveting. You can also go for undamped front sprockets, which is what I used. I honestly can't tell the difference. Chain tools are not expensive at all and there are lots of good videos on youtube on how to use them. Articles I read suggested that clips links are only to be used where you need to make a lot of quick sprocket adjustments (race bikes) or low engine sized bikes. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted June 25, 2020 Supporting Member Share Posted June 25, 2020 @nhchris I have used master links on my race bikes and street bikes for years and never had a problem. If I did remove the master link I always replaced the locking clip and used master link pliers for install and removal. The most power full bike I used a master link on was a BMW S1000rr. He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
captainscarlet Posted June 25, 2020 Share Posted June 25, 2020 So the new chain is now on. I must say it feels much more robust than the OEM item. The job was relatively straight forward and thankfully I was able to borrow a decent chain breaking and riveting tool from a friend. It will be interesting to see, feel and hear how the bike now feels. CS 3 Link to comment Share on other sites More sharing options...
captainscarlet Posted June 29, 2020 Share Posted June 29, 2020 Managed to get out on my first ride this Sunday since changing the chain and sprockets at the end of last week. I must say there was a noticeable difference, with less vibration and a more general feeling of smoothness. Also my quickshift, which is generally already smooth, was like butter. All in all I'm glad I changed the drive train. CS 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 29, 2020 Supporting Member Share Posted June 29, 2020 48 minutes ago, captainscarlet said: Managed to get out on my first ride this Sunday since changing the chain and sprockets at the end of last week. I must say there was a noticeable difference, with less vibration and a more general feeling of smoothness. Also my quickshift, which is generally already smooth, was like butter. All in all I'm glad I changed the drive train. CS New chains and new tires always make a bike feel smoother and rejuvenated. 😎👍 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
peteinpa Posted October 9, 2020 Share Posted October 9, 2020 Sad to hear the origional chain is dying at 12k miles. I'm now lubing mine at least every 200 miles. Some tips on chains: Signs of wearing out. First you get kinks, then that red dust, then noise, vibration, can't set freeplay. To remove old chain just cut through the sideplates with cut off wheel on Dremel. AFTER removing countershaft nut. Why stress out or break your rivet tool needlessly. Cuts through quickly like butter. I always replaced front sprocket with every chain, rear every other chain. If you're going to change gearing, always go bigger. less stress on chain. Don't go smaller on front, go bigger on rear. Smaller front causes chain to curve tighter for more wear. For me, top of the line DID chain, nothing else. always got me to at least 20k miles on my CBR1100XX. I can't believe they even sell clip type master links anymore. Rivet only for me. 1 Link to comment Share on other sites More sharing options...
Ride365 Posted October 9, 2020 Share Posted October 9, 2020 I plan on installing my Tuturo oiler system on my new GT, you get insane mileage out of chains/sprockets with these oilers. I find mine no more messy than any spray lube, plus all I EVER do is wipe the chain down on occasion with a rag. Link to comment Share on other sites More sharing options...
