Clicknow Posted June 23, 2020 Share Posted June 23, 2020 Hi just got back from a short ride and was using cruise control without any problems then all of a sudden the cruise control light started flashing and cruise control would not work,anyway I needed some petrol so stoped to fill up,started bike again and all was back to normal very strange anyone else had similar problem? Regards graham Link to comment Share on other sites More sharing options...
johnmark101 Posted June 23, 2020 Share Posted June 23, 2020 Have not experienced this with my cruise control. I would not be too concerned about it unless it happens again. 1 There is nothing like spending a day riding with friends in the grip of a shared obsession. Link to comment Share on other sites More sharing options...
Premium Member duhg Posted June 23, 2020 Premium Member Share Posted June 23, 2020 I have occasionally had the same thing happen. Turning the ignition switch off and on again resets it. I have no idea what the problem was. 1 https://ridemsta.com/oh-tmr/ Riding makes me happy. "Do it or don't do it - you'll regret both." - Soren Kierkegaard 2015 FJ-09, 60k miles, Hord Power ECU, K-Tech suspension, MC Cruise Link to comment Share on other sites More sharing options...
Dodgy Knees Posted June 23, 2020 Share Posted June 23, 2020 1 hour ago, duhg said: I have occasionally had the same thing happen. Turning the ignition switch off and on again resets it. I have no idea what the problem was. This is the answer to most modern electronic failures. 👍 5 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted June 23, 2020 Supporting Member Share Posted June 23, 2020 2 hours ago, Dodgy Knees said: This is the answer to most modern electronic failures. 👍 Absolutely, when in doubt, power cycle the device. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
trevinator Posted June 23, 2020 Share Posted June 23, 2020 (edited) 13 minutes ago, betoney said: Absolutely, when in doubt, power cycle the device. had to do this when the power windows in my jeep stopped working. shutting it off and starting it back up made them work fine again. like a glitch in the matrix. Edited June 23, 2020 by trevinator 1 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted June 23, 2020 Supporting Member Share Posted June 23, 2020 I work in IT and literally have this on a t-shirt 2 3 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
reiny Posted June 26, 2020 Share Posted June 26, 2020 Happens to me as well fairly often. Sometimes the power cycle trick works, sometimes not. My research on an FZ10 forum, where the same problem exists, some people have said that it's the switch assembly in the front brake. 1 Link to comment Share on other sites More sharing options...
tktplz Posted June 26, 2020 Share Posted June 26, 2020 On 6/23/2020 at 5:06 PM, betoney said: Absolutely, when in doubt, power cycle the device. Known in our business as a POR. Power Off Reset. 2 Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
Nashtele Posted July 18, 2020 Share Posted July 18, 2020 I have had it happen to me several times as well. It always seems to happen right when I start a long stretch and do not want to have to take the time to pull off and cycle through the power. For something that was invented in 1948, you'd think they'd have it figured out by now. Especially Yamaha. I'm still under warranty so I'll mention it the next time I'm in for service and post an update if I learn anything new. Link to comment Share on other sites More sharing options...
Cornersruns Posted July 19, 2020 Share Posted July 19, 2020 On 6/23/2020 at 11:53 PM, knyte said: I work in IT and literally have this on a t-shirt You also need Roy's T-Shirt from this image - RTFM 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 19, 2020 Supporting Member Share Posted July 19, 2020 7 hours ago, Cornersruns said: You also need Roy's T-Shirt from this image - RTFM 😄 SO true 👍 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
09ing Posted August 1, 2020 Share Posted August 1, 2020 I just went through this my GT. Turned out the front brake light switch would stick on and cruise won't work and light flashes. Turn off bike restart and its fine tell the switch sticks again. To trouble shoot this i put a wire tie around the switch to hold the plunger in for two weeks and it never acted up, then slid the wire tie down so the switch would work and it started doing it again. Ordered a new switch from Partzilla $66.00 and change and shipping. True your brake light won't come on when using the front brake but still have foot brake to light it up. I chased this problem for six weeks. Seems that when the module sees brake light on and the bike is not slowing it disables the cruise untell the bike is turned off and restarted. Hope that helps. Also you can try key on engine off working the front brake lever and watch the brake light if it stays on at all after releasing the lever its bad. Rob out. 6 Link to comment Share on other sites More sharing options...
reiny Posted August 1, 2020 Share Posted August 1, 2020 Thanks for this 09ing, would you mind sending me the ling to the part you ordered? thanks Link to comment Share on other sites More sharing options...
09ing Posted August 3, 2020 Share Posted August 3, 2020 On 7/31/2020 at 11:19 PM, reiny said: Thanks for this 09ing, would you mind sending me the ling to the part you ordered? thanks PM sent. Link to comment Share on other sites More sharing options...
