Supporting Member dazzler24 Posted August 30, 2021 Supporting Member Share Posted August 30, 2021 Installed my McCruise speedo correction 'kit' the other day while doing a multiservice (Rear shock, Throttle body sync, oil change, etc). But when it came to calibrating it, the instructions say to go into diagnostic mode. This requires the pressing of the SET and RES buttons together while turning on the ignition. This is all fine and dandy if you have the McCruise original switches which will allow you to do that BUT I modified my controller to use a stock OEM module which of course only allows for either SET OR RES to be pressed via the rocker switch but not both concurrently! Oops! never saw that coming when I did the mod. If you too have done this little mod and find yourself in the same situation in future, there is a workaround that will get you out of the doo-doo with minimal effort required. I could have rewired my McCruise original switch to a Molex connector and plugged it into the computer end temporarily to set it up then return to normal which would have meant sourcing the plug and pins and putting it together for just this one-time job OR - get creative! The McCruise uses voltage sensing on a common line to determine SET or RES and likewise for diagnostic mode. Looking at the control board there are two resistors of different values associated with the SET and RES buttons and they are wired in parallel but are separate from each other in normal use. These are placed in parallel when both buttons are pressed at once however giving diag mode - but only when turning on the ignition. For those who may not be aware, when two resistors are in parallel the resulting resistance is a function of the two using a formular which I'll not bore you with but is always less than the smallest resistor. So, it was simply a matter of unplugging my OEM style controller from the McCruise brain and placing a resistor of the abovementioned determined value (530ohms FWIW) across the common and SET/RES control line, turning the ignition on and Viola! we have diag mode. Then removed resistor and plugged my OEM control back in to complete configuration of the speedo correction. Sorry for the long post but someone might get some use out of it if they have a similar setup to me. 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted August 31, 2021 Supporting Member Share Posted August 31, 2021 Very creative workaround, glad you got it to work. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted September 3, 2021 Supporting Member Share Posted September 3, 2021 On 8/31/2021 at 12:52 PM, betoney said: Very creative workaround, glad you got it to work. ...Eventually! Took it out for a run yesterday as it was the first chance I had since doing the calibration in the garage. Got about 100M from home and noticed I had TCS and Check Engine lights up. Also, NO speedo reading at all which probably explains why the alarm lights were up. Back home and re-read the instructions and it seems that sometimes the power required for the speedo correction CCT is not enabled by default within the McCruise brain. Thankfully that's all it was. Turned it on via the diag mode, went through the calibration again and now all is good. I had to do a second recalibration out on the road as it was a little high at 100KM/h (i.e., GPS reading 102 @ 100 on the speedo). Not much I know but when it can be dialled in precisely, why not! It's nice to now be confident that what the speedo reads is going to be very close to the real speed. FWIW mine was out around 8%. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted September 3, 2021 Supporting Member Share Posted September 3, 2021 8 hours ago, dazzler24 said: ...Eventually! Took it out for a run yesterday as it was the first chance I had since doing the calibration in the garage. Got about 100M from home and noticed I had TCS and Check Engine lights up. Also, NO speedo reading at all which probably explains why the alarm lights were up. Back home and re-read the instructions and it seems that sometimes the power required for the speedo correction CCT is not enabled by default within the McCruise brain. Thankfully that's all it was. Turned it on via the diag mode, went through the calibration again and now all is good. I had to do a second recalibration out on the road as it was a little high at 100KM/h (i.e., GPS reading 102 @ 100 on the speedo). Not much I know but when it can be dialled in precisely, why not! It's nice to now be confident that what the speedo reads is going to be very close to the real speed. FWIW mine was out around 8%. I have the original MCCruise (v1.0 I think) and don't think there are any 'upgrades' or 'add-ons' available for it. I ride with a GPS 100% of the time and fortunately there is only a 2mph difference in readings, which I am fine with. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted September 4, 2021 Supporting Member Share Posted September 4, 2021 16 hours ago, betoney said: I have the original MCCruise (v1.0 I think) and don't think there are any 'upgrades' or 'add-ons' available for it. I ride with a GPS 100% of the time and fortunately there is only a 2mph difference in readings, which I am fine with. I think that I would be happy with that small error as well. FWIW, this is my label and the two important parts that were required for this to work were: - MCS7320TBW and Firmware version 5.157+ I was required to send this info to McCruise first so that I was sent the 'right' kit. They may have other versions that work as well but would require an enquiry from anyone who may be interested. 1 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted May 10, 2022 Author Supporting Member Share Posted May 10, 2022 UPDATE: I can't believe I haven't had the tires off until now. Installed the ABS rings last night, complete with an obligatory Cambodian Tire #25 Torx fail - the tool seemed soft, and rounded out the )_^&&* fastener. Thankfully an EZ Out did the trick. Anyway, on the ride to work this AM, at 50 km/h (GPS reading) the speedo reads 51 km/h. @ 40 it reads 38. That's deadly accurate! Sure happy to be able to read the large-font dash instead of the microscopic GPS eye-test. 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
