Samaha Posted July 20, 2020 Share Posted July 20, 2020 I installed a set of Aux lights using an LED wiring harness with a switch. The install took 90 minutes including adjustment of the lights. Project materials and tools: · AutoTime 2 Pack 3.5 Inches 25W LED Work Light Flood Spot Combo $57 · DZG Universal LED Light Wiring Harness Kit with Relay and On/Off Switch $18 · 20MM X 3MM (~8”) Black Mending Bracket $3 · 2 Washers · 2 rubber grommets (optional) · Heat Shrink Wire Connectors · Heat Shrink Crimping Tool · Heat Gun Steps Step 1 – TEST by connecting Wire Harness to lights and Power/or Fuse Box (See Aux Light Install 1). Step 2 - Appropriately run the wires from power to the lights and switch. I ran mine underneath the plastic side fairings and zip tied to existing wires. For the switch, I did the same, going up the fork column to the handlebar; make sure you allow some wiggle room for turning. (See Aux Light Install 2) Step 3 – Line up the mending bracket to furthest part of the fairing and drill two holes in the plastic. Ensure there is space to push through a screw by gauging with your finger. NOTE: If you prefer not to drill into the plastic, you can use the existing holes. I used the existing holes for the light wires and inserted a rubber grommet on each side. (See Aux Light Install 3a and 3b) Step 4 – Mount the lights loosely using the included hardware. Push the screw through the light bracket, mending plate and fairing hole. On the inside, be sure to use a metal washer between the plastic and lock nut (See Aux Light Install 4) Step 5 – Use 2 zip ties to further secure the plate by looping through each bracket located directly above the existing holes. (See Aux Light Install 5a and 5b) Step 6 – Adjust and tighten the lights to the desired angle. (See Aux Light Install 6a, 6b and 6c) 3 3 Link to comment Share on other sites More sharing options...
Supporting Member knyte Posted July 20, 2020 Supporting Member Share Posted July 20, 2020 (edited) Looks great!! Thanks for the excellent write-up, you're giving me some ideas... ...still far to clean, though Edited July 20, 2020 by knyte 1 2015 FJ-09 / FJR touring bags / oil plug mod / Evotech rad guard / SW Motech bash plate / VStream touring windshield / Seat Concepts: Sport Touring / Vcyclenut ABS rings (speedo correction) / Cosmo RAM mount Link to comment Share on other sites More sharing options...
Samaha Posted July 20, 2020 Author Share Posted July 20, 2020 2 minutes ago, knyte said: Looks great!! Thanks for the excellent write-up, you're giving me some ideas... ...still far to clean, though lol, thank you. happy to add more pics of different angles if you want. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 20, 2020 Supporting Member Share Posted July 20, 2020 Good job, looks like a clean install. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
WKE002 Posted July 20, 2020 Share Posted July 20, 2020 Great ! Was checking around youtube, no one actually zoom in on the exact placement bracket as always taken from far... HUH! That have hold me back on purchasing and DIY myself till am very confident to install. Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted July 21, 2020 Supporting Member Share Posted July 21, 2020 1 hour ago, Samaha said: Step 5 – Use 2 zip ties to further secure the plate by looping through each bracket located directly above the existing holes. ...do the zip ties need to be there? Is the flat bar secured to just the plastic above it or something more solid? Link to comment Share on other sites More sharing options...
Samaha Posted July 21, 2020 Author Share Posted July 21, 2020 19 minutes ago, piotrek said: ...do the zip ties need to be there? Is the flat bar secured to just the plastic above it or something more solid? Its up to you. My lights are 1 lb each so i felt more comfortable adding a second layer of support. Regarding the second part of your question, the lights are attached to the plastic with the flat bar on the outside and a metal washer inside. The attached pic is a very poor attempt to illustrate. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted July 21, 2020 Supporting Member Share Posted July 21, 2020 The sketch describes it well. The lights look great. Just monitor for the plastic bits coming sloppy or fatigued over time. Consider steel supports that mount up to the framing parts... if available that is. 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted July 21, 2020 Supporting Member Share Posted July 21, 2020 @Samaha - I agree with @piotrek about possibly needing a steel support. Grab the front of the light housing and gently move it up and down to see if it moves or the plastic flexes - at all, then imagine hitting a few potholes and see if it is secure enough. Better safe than sorry. 2 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Samaha Posted July 21, 2020 Author Share Posted July 21, 2020 thank you. Fair points. i will look into a way of supporting it a steel support. For now the zips dont allow any flex but as stated, it could become fatigued over time. 1 Link to comment Share on other sites More sharing options...
Samaha Posted July 26, 2020 Author Share Posted July 26, 2020 On 7/20/2020 at 9:28 PM, betoney said: @Samaha - I agree with @piotrek about possibly needing a steel support. Grab the front of the light housing and gently move it up and down to see if it moves or the plastic flexes - at all, then imagine hitting a few potholes and see if it is secure enough. Better safe than sorry. UPDATE: After receiving feedback from this forum, I decided to mount the lights to steel supports on the bike. I used the following parts: · One 12 inch 3/8 threaded rod – used rubber mallet to push through $1.50 · 2 20MM X 3MM (~8”) Black Mending Bracket $6 · 4 3/8 washers 30 cents · 4 3/8 Lock nuts 60 cents · Two 2 inch elbow brackets 60 cents · Dual Camera Mount Flash Bracket Extension Bar 10.6'' $10 Step 1- Push the threaded rod through the hollow metal cylinder as shown in Aux Light Install 7 and make sure it’s the same length coming out of each side (approx1.5 inches). Use (use 3/8 Lock nuts to secure on each side) Step 2 – Fasten the mending brackets on each side. Before you mount the bracket ensure you run the bracket through the bottom of the fairing as shown in Aux Light Install 8. To Mount the bracket I used 2 washers, then put on the bracket and then secured with another 3/8 locknut as shown in Aux Light Install 8a. Step 3 – Attach 2 elbow brackets to each side of the mending plates as shown in Aux Light Install 9. I drilled some extra holes into the mending bracket to accommodate the holes in the elbow bracket. Step 4- Attach the Dual Camera Mount Flash Bracket Extension Bar to the top of the elbow brackets and light beneath as shown in Aux Light Install 10. Remove any slack and tighten everything up. 6 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted July 27, 2020 Supporting Member Share Posted July 27, 2020 Clever re-design. Replace these bolts (each side) and you're golden. 😬 2 Link to comment Share on other sites More sharing options...
Salish900 Posted October 15, 2020 Share Posted October 15, 2020 I'm going to add aux lights sooner than later and appreciate this information. What is meant by Aux light install 10 in each section? Is it only referring to the photos? Or is there some DIY narrative somewhere? Link to comment Share on other sites More sharing options...
Ride365 Posted October 15, 2020 Share Posted October 15, 2020 Bravo sir......BRAVO, perhaps I could ride up there to PA one of these days and you can she me how it's done? Love your bike by the way, not sure why some don't like the color of our new 2020 GT's? 1 Link to comment Share on other sites More sharing options...
