thewrenchbender Posted July 26, 2020 Share Posted July 26, 2020 Trying to locate 2 pin OEM type turn signal connectors. Indicator end, not bike end. Have found multiple sources for 3 pin connectors and 3 pin splitters. The closest I’ve found is MamaYama Europe shows 2 pin to bullet connector harnesses, but I can’t seem to find an online vendor that stocks/sells them. Would like to swap out the great pumpkin assemblies with the Yamaha Euro accessory replacements, can find the plain black and “carbon matt” signals, but am not going to cut the existing bike-side connectors off the harness to fit them... Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted July 26, 2020 Supporting Member Share Posted July 26, 2020 Hi @thewrenchbender - I swapped the stock pumpkin signals on my 2015 FJ for LEDs from a Super Tenere. On the FJ, the front and rear signals use the same factory 3-pin connectors, but the rears only have two wires connected (no running lights on the rear). I would assume it’s the same setup on the newer Tracer models, although I can’t verify that personally. This thread has a lot of useful details, and includes a link to the 3-pin connectors I used for my conversion. Good luck! -Scott Link to comment Share on other sites More sharing options...
thewrenchbender Posted July 26, 2020 Author Share Posted July 26, 2020 33 minutes ago, texscottyd said: Hi @thewrenchbender - I swapped the stock pumpkin signals on my 2015 FJ for LEDs from a Super Tenere. On the FJ, the front and rear signals use the same factory 3-pin connectors, but the rears only have two wires connected (no running lights on the rear). I would assume it’s the same setup on the newer Tracer models, although I can’t verify that personally. This thread has a lot of useful details, and includes a link to the 3-pin connectors I used for my conversion. Good luck! -Scott Thanks Scott Tracer GT (mine anyways) only has 2 pin/2 wire flat rectangular connectors instead of the round 3 pin front and rear. Fronts are continuously lit as marker lights, then interrupted to signal. Mark 1 Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted July 26, 2020 Supporting Member Share Posted July 26, 2020 Good to know... Thanks! It certainly makes sense to use a 2 wire connector at the rear, but I didn’t know Yamaha had made that change from the earlier bikes. So the front on the GT is a 2 pin connector, also? Interesting... Worst case, you could cut the connectors off the stock signals and wire them onto the replacements. Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted July 27, 2020 Premium Member Share Posted July 27, 2020 Tripage LED should be able to build the harness for you. Link to comment Share on other sites More sharing options...
thewrenchbender Posted July 29, 2020 Author Share Posted July 29, 2020 On 7/26/2020 at 1:37 PM, thewrenchbender said: Thanks Scott Tracer GT (mine anyways) only has 2 pin/2 wire flat rectangular connectors instead of the round 3 pin front and rear. Fronts are continuously lit as marker lights, then interrupted to signal. Mark Took the front end back apart to tweak the fork tubes-brain fart-front is a “round” three wire connector. Need to do some re-thinking. I’ll blame it on Corona... Link to comment Share on other sites More sharing options...
Premium Member Motocheck Posted July 29, 2020 Premium Member Share Posted July 29, 2020 On 7/26/2020 at 2:24 PM, texscottyd said: Good to know... Thanks! It certainly makes sense to use a 2 wire connector at the rear, but I didn’t know Yamaha had made that change from the earlier bikes. So the front on the GT is a 2 pin connector, also? Interesting... Worst case, you could cut the connectors off the stock signals and wire them onto the replacements. I cut the connector off the stock turn signals and wire them with new led turn signals or you can buy new. OEM Turn Signal Connectors and Y-Splitters – Tracer 900 GT – Custom LED These OEM turn signal and Y-Splitter... Link to comment Share on other sites More sharing options...
