Lone Wolf Posted August 29, 2020 Share Posted August 29, 2020 (edited) 20 hours ago, piotrek said: Doesn't have BMW stamped all over it... there is hope Regina might make it available to the commoners at some point. I would buy that chain from Regina - but I would still lube it. Unless the O-rings / X-rings are made of unobtanium, they would eventually dry out and crack, pieces of rubber sticking out like any other chain that has high miles. That is why I clean and lube chains, to preserve the rubber rings - hoping the INTERNAL lube stays in place as long as it can. "At first glance, the M Endurance is a typical X-ring design, with a permanent lubricant filling between the rollers and pins. The secret, says BMW, is a new coating material called tetrahedrally amorphous carbon (ta-C), a type of industrial diamond, to the rollers and bushings." I like the steel, because that wear is why chains "stretch" but you still have to try to keep the seals intact. Otherwise you lose the internal lubricant. Edited August 29, 2020 by Lone Wolf 2 1980 Yamaha 850 Triple (sold). Too many bikes to list, FJ-09 is next on my list Link to comment Share on other sites More sharing options...
nhchris Posted August 29, 2020 Share Posted August 29, 2020 2 hours ago, kmev said: With out regular applications of moly to all drive splines, including the transmission input splines (which requires pulling the transmission) the splines self destruct and you're eventually left with a bike that revs but doesn't move. Even with regular maintenance, my K75 was showing wear at 60,000 miles. Not on a Honda!! I ran my ST 1300 for 50k miles and changed the 90w shaft drive hypoid gear oil every other engine oil change. Never a squeak, shudder or problem from that clean and quiet shaft. People say Hondas are boring. If you love wrenching and all sorts of maintenance that is definitely true. You will be bored (and possibly stroked). 1 1 1968 Triumph Bonneville 650 1971 Norton Commando Roadster 2002 Harley 1200 Sportster 2003 Honda ST 1300 2016 FJ 09 Link to comment Share on other sites More sharing options...
kmev Posted August 29, 2020 Share Posted August 29, 2020 1 hour ago, nhchris said: Not on a Honda!! Nor a Yamaha - that's why I am here. 1 Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted August 30, 2020 Supporting Member Share Posted August 30, 2020 (edited) 4 hours ago, nhchris said: I ran my ST 1300 for 50k miles and changed the 90w shaft drive hypoid gear oil every other engine oil change. Never a squeak, shudder or problem from that clean and quiet shaft. That is more like what I had imagined shaft drive maintenance to be. Edited August 30, 2020 by piotrek 2 Link to comment Share on other sites More sharing options...
Buggy Nate Posted August 30, 2020 Share Posted August 30, 2020 7 hours ago, kmev said: Nor a Yamaha - that's why I am here. Disagree there. Yamaha’s Xvs650 is the worst driveshaft/diff in the world. Constant issues with howling stripped splines etc. Almost impossible to find a second hand shaft drive here. Link to comment Share on other sites More sharing options...
kmev Posted August 30, 2020 Share Posted August 30, 2020 (edited) 2 hours ago, Buggy Nate said: Disagree there. Yamaha’s Xvs650 is the worst driveshaft/diff in the world. Constant issues with howling stripped splines etc. Almost impossible to find a second hand shaft drive here. I'm not familiar with that bike. I know the FJR1300 drive is bulletproof, as was my old Maxim 700's drive back in the day. It seems BMW's entire line was prone to problems. Edited August 30, 2020 by kmev Link to comment Share on other sites More sharing options...
Buggy Nate Posted August 30, 2020 Share Posted August 30, 2020 1 hour ago, kmev said: I'm not familiar with that bike. I know the FJR1300 drive is bulletproof, as was my old Maxim 700's drive back in the day. It seems BMW's entire line was prone to problems. It was a 650cc vtwin hardly rideable lookalike. Hideously heavy as well. Even learner approved here because of the terrible power to weight figures. Link to comment Share on other sites More sharing options...
Lone Wolf Posted August 30, 2020 Share Posted August 30, 2020 6 hours ago, Buggy Nate said: Disagree there. Yamaha’s Xvs650 is the worst driveshaft/diff in the world. Constant issues with howling stripped splines etc. Almost impossible to find a second hand shaft drive here. Were you the original owner? Sounds like a high-miles bike that may not have been lubricated by original owner. My 1980 Yamaha 850 Triple and 1982 Yamaha 750 Seca both had awesome shaft drives. Others mention the FJR and Maxim with no problems. Yamaha does know how to make a great shaft drive. 3 1980 Yamaha 850 Triple (sold). Too many bikes to list, FJ-09 is next on my list Link to comment Share on other sites More sharing options...
Supporting Member roadrash83 Posted August 30, 2020 Supporting Member Share Posted August 30, 2020 6 hours ago, Lone Wolf said: Were you the original owner? Sounds like a high-miles bike that may not have been lubricated by original owner. My 1980 Yamaha 850 Triple and 1982 Yamaha 750 Seca both had awesome shaft drives. Others mention the FJR and Maxim with no problems. Yamaha does know how to make a great shaft drive. I have to agree with you. I bought a new 79 Yamaha XS1100, when I was eighteen and never had a drive shaft problem with over a 100,000 miles. I beat the living shit out of that bike and could not kill it, changed the oil and filter ever 3000mi and the shaft drive 90w every other oil change. The only problem I ever had with the bike was leaking fork seals, I think I put eight sets on in the time I owned the bike. Like I said, I had fun with it😀 1 He who dies with the most toys wins. Link to comment Share on other sites More sharing options...
Buggy Nate Posted August 30, 2020 Share Posted August 30, 2020 8 hours ago, Lone Wolf said: Were you the original owner? Sounds like a high-miles bike that may not have been lubricated by original owner. My 1980 Yamaha 850 Triple and 1982 Yamaha 750 Seca both had awesome shaft drives. Others mention the FJR and Maxim with no problems. Yamaha does know how to make a great shaft drive. I’m offended you think I’d own one of them...! I was a mechanic. The amount of these we had through with buggered shaft drives were astonishing. Yamaha put absolutely bugger all grease in the splines from new too. Link to comment Share on other sites More sharing options...
tktplz Posted August 30, 2020 Share Posted August 30, 2020 (edited) On 8/28/2020 at 9:58 PM, piotrek said: Doesn't have BMW stamped all over it... there is hope Regina might make it available to the commoners at some point. That's what I was wondering. Will I have to buy the complete BMW to get the chain for my bike? Edited August 30, 2020 by tktplz spelling.....DOH! Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 30, 2020 Supporting Member Share Posted August 30, 2020 Does anyone else remember the XV920R of the early 80s? It was a more sporting version of the Virago, and had a really unique enclosed chain that ran in its own oil bath. I thought it was a great idea, and I’m surprised that it wasn’t more widely adopted. 1 Link to comment Share on other sites More sharing options...
tktplz Posted August 31, 2020 Share Posted August 31, 2020 1 hour ago, texscottyd said: Does anyone else remember the XV920R of the early 80s? Yes I do. I was thinking that was the way BMW was going to do it. 1 Ain't no fun when the rabbit gets the gun! Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted August 31, 2020 Supporting Member Share Posted August 31, 2020 1 hour ago, tktplz said: Yes I do. I was thinking that was the way BMW was going to do it. Me too! It’s such an obvious approach/solution, I don’t know why it hasn’t reappeared... Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted August 31, 2020 Premium Member Share Posted August 31, 2020 7 hours ago, Buggy Nate said: I’m offended you think I’d own one of them...! I was a mechanic. The amount of these we had through with buggered shaft drives were astonishing. Yamaha put absolutely bugger all grease in the splines from new too. If you were born in 81, those Yamahas were pretty well used by the time you worked on them. The main thing with the old style shaft drives (I had a Suzuki 850 4 with the shaft, nice mellow thing), was they didn't have a second universal joint back before the rear transfer, and were thus very sensitive to abrupt on-off throttle application which caused jacking and de-jacking of rear wheel. All "modern" shaft drives have minimal jacking effect. Enclosed oil bath primary chain AND rear final drive chains are old as the hills, and I agree they CAN be very effective. Belts are OK but not being able to juggle sprocket sizes is not appealing to me. Whereas the new BMW forever chain is only a $100 dollar option for a new XR, replacement is $400 and what about the sprockets? Why not "diamond-like" coat them too? Link to comment Share on other sites More sharing options...
