Supporting Member Heli ATP Posted April 6, 2022 Supporting Member Share Posted April 6, 2022 https://japan.webike.net/products/21958168.html What is the 'Yamaha Wire Lead Sport 2'. Part # Q5K-YSK-001-U48 Comment says... *Power is supplied only as the headlights are on. Does that mean it could be used to power AUX light to come on with the headlights? Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted April 13, 2022 Author Supporting Member Share Posted April 13, 2022 On 3/3/2022 at 10:55 AM, karamurat said: Selamlar, ön aydınlatma kadar arka stop lambaları da çok önemli,çekim kalitesi için özür dilerim Good looking lights. Do you have a closer picture of how you mounted the lights? 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted June 27, 2022 Author Supporting Member Share Posted June 27, 2022 On 4/5/2022 at 11:19 PM, Heli ATP said: https://japan.webike.net/products/21958168.html What is the 'Yamaha Wire Lead Sport 2'. Part # Q5K-YSK-001-U48 Comment says... *Power is supplied only as the headlights are on. Does that mean it could be used to power AUX light to come on with the headlights? Sorry - thought I had responded to this. This looks like a Y adapter that could be used for auxiliary lights. so long as the auxiliary lights are relatively low current draw this may be sufficient if you don't have a separate relay/switch to allow you the flexibility of turning on the auxiliary lights independently of the headlights. 1 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted June 27, 2022 Supporting Member Share Posted June 27, 2022 I've decided to remove my stock mirrors as they are not really useful after adding the FJ-09 hand guards. The handle bar bar mirrors work very well even though I need to upgrade from the cheap ones I installed for function test. Currently I think the look is a little odd on my GT with so many things sticking out on the sides. My plan is the put lights where the stock mirrors mount, and since wiring is already at that location it should be straight forward. This will be a winter project so for now I'm looking for inconspicuous running or fog lights that maybe have a turn signal option. I have turn signal light on my hand guards that need to be wired up so if I just add fog light to the mirror location I will be good to go. After-market light suggestions appreciated. 1 Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted June 28, 2022 Author Supporting Member Share Posted June 28, 2022 11 hours ago, Heli ATP said: I've decided to remove my stock mirrors as they are not really useful after adding the FJ-09 hand guards. The handle bar bar mirrors work very well even though I need to upgrade from the cheap ones I installed for function test. Currently I think the look is a little odd on my GT with so many things sticking out on the sides. My plan is the put lights where the stock mirrors mount, and since wiring is already at that location it should be straight forward. This will be a winter project so for now I'm looking for conspicuous running or fog lights that maybe have a turn signal option. I have turn signal light on my hand guards that need to be wired up so if I just add fog light to the mirror location I will be good to go. After-market light suggestions appreciated. I've been looking to do something similar but cannot find a good turn signal replacement blinker that I like yet. Had to start a whole new thread just on mirrors.... 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted August 29, 2022 Author Supporting Member Share Posted August 29, 2022 From a Swiss Niken owner. First time seeing this style of fork mounted setup. 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
karamurat Posted December 1, 2022 Share Posted December 1, 2022 (edited) Bağlantısını yaptığınız ek aydınlatıcı ana fardan uzakta olmalıdır. Ama fazla dışarı taşmamalı. Edited December 1, 2022 by karamurat yazım hatası 1 Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted December 1, 2022 Author Supporting Member Share Posted December 1, 2022 8 hours ago, karamurat said: Bağlantısını yaptığınız ek aydınlatıcı ana fardan uzakta olmalıdır. Ama fazla dışarı taşmamalı. Very interested in how you attached that there. Any additional close up photos of how you attached it? 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted February 28, 2023 Author Supporting Member Share Posted February 28, 2023 This just in from a fellow owner. Mounting lights on the suspension directly to the bolts was clever. Personally like the stealthy look and if you have these style/size of lights this may be a potential mounting solution. One must be sure that the auxiliary lights in question aren't so large that they end up interfering with the front suspension clearance while leaning/turning. 1 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted February 28, 2023 Supporting Member Share Posted February 28, 2023 5 hours ago, maximNikenGT said: Mounting lights on the suspension directly to the bolts was clever. Any chance of a closer pic of the installation and brand name of lights? Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted March 1, 2023 Author Supporting Member Share Posted March 1, 2023 Will check with original poster out of Spain. 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
Supporting Member maximNikenGT Posted October 24, 2023 Author Supporting Member Share Posted October 24, 2023 Reposting from another thread - anyone attempted using LED cornering lights from a FJ1300 or Tracer 9 GT into the Niken? I know Yamaha has the tech - just not sure how hard it would be to make it work with the Niken or if the front end cowling will even fit the new cornering lights or if the IMU will even work correctly with an LED from another Yamaha model. 2019 Niken GT "Motorcycles - the brand is not important, the fact that you ride is." Link to comment Share on other sites More sharing options...
