Powerbronze Tracer 900 2015-2017 products
Hello Everyone,
I hope your all well and staying safe under the current conditions ?
Powerbronze have developed a range of products for the Tracer 900 2015-2017 model as follows (click the links below each product to view them individually on the site or click the link below to view the whole range):
Powerbronze Tracer 900 2015-2017 product range
All of these products have been designed and manufactured by Powerbronze at our factory in the UK.
Due to the number of products we make for this model, I have had to limit the number of pictures that I can upload to this thread. I have uploaded a number of pictures of the individual products.  If you would like specific photos of all of the products, click on the links below each item and they will take you to the page on our website.
Bike Fitted with Powerbronze Belly Pan
Bike Fitted with Powerbronze Fairing Lowers
Beak - £95
- Available in Matt Black finish
- Made from high-impact ABS plastic
- Supplied with all required fittings and full instructions
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-350-y102.html
Beak - £95 (Fits With Fog Lights)
yamaha-_mt-09-tracer_15-16_fj-09-tracer_15-16-_fits-with-fog-lights_-beak-350-y103-1.jpg.2da5d2f775e302d96bfa1a4d016d0c4c.jpg
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-fits-with-fog-lights-350-y103.html
Flip Screen - £98
- Available in 2 colours
- Made from 4 mm acrylic
- 530 mm high x 380 mm wide
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-530-mm-40-mm-wider-420-y142.html
Flip Screen - £98
- Includes cutouts for hand guards
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-530-mm-90-mm-wider-420-y143.html
Standard Screen - £75
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-410-y164.html
Adventure Sport Screen - from £59
- Available in 17 colours
- 330 mm high
- Made from 3 mm acrylic
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-330-mm-460-y103.html
Headlight Protector - from £27
- Available in 14 colours
- Clear, Light Tint and Yellow are road legal
- Supplied with fitting kit and instructions.
- Easy removal for cleaning
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-440-y557.html
Hand Guards - £70
- Available in Matt Black and Carbon Look (*) finishes
- Simple and easy to fit (direct replacements)
* While stock of Carbon Look lasts
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-380-y101.html
Mudguard Extender - £25
- Available in Gloss & Matt Black finishes
- Fitment with screws or plastic rivets
- All fittings supplied
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-650-y112.html
Rear Hugger - from £99
- Available in Gloss Black, Matt Black & Carbon Look finishes
- Simple to fit, no drilling
- Supplied with full fitting kit and instructions
- Use Posi-flex steel sleeved rubber mounting points to dampen vibration and avoid stress cracking
- Exterior finish does not require painting and is UV protected to avoid sun damage
* Limited stock of Carbon Fibre finishes available on the Rear Hugger
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-16-mt-09-tracer-fj-09-tracer-15-17-xsr900-16-19-201-y106.html
Belly Pan - £125
- Available in Gloss Black & Matt Black finishes with Silver meshed vents
* Fits both Tracer 900 models (2015-2017 & 2018-2020)
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-19-fj-09-tracer-15-19-mt-09-tracer-gt-18-19-fj-09-tracer-gt-18-19-320-y118.html
Belly Pan - £125 (Fits with Yamaha Engine Protectors)
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-19-mt-09-tracer-gt-18-19-fj-09-tracer-15-19-fj-09-tracer-gt-18-19-fits-with-yamaha-engine-protectors-320-y119.html
Fairing Lowers - £275
- Manufactured from high impact ABS plastic
- Simple easy to fit instructions
- Available in a variety of colour finishes
- UV stable
- Rubber mounted fixing points to avoid vibration stress
* Limited stock of Gloss Black with Silver mesh available
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-110-y104.html
Fairing Lowers - £275 (Fits with Yamaha Engine Protectors)
- UV stable
mt-09-tracer-_with-crash-pro_-lowers-black-matt-22.jpg.bae5d7dcbf2bf3eca85fb02fe3358f85.jpg
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-fits-with-yamaha-engine-protectors-110-y105.html
Crash Posts (Protectors)
- 2 options for fitting positions (Front or Rear mount points)
- Available in aerodynamic shaped high impact plastic
- Available in anodised CNC machined finish
- 10 colour options to compliment your bike
- Removable end cap to hide engine mounting bolt
- Designed and manufactured by Powerbronze in Great Britain
Front Set - https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-16-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-front-set-513-y131.html
Rear Set - https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-rear-set-513-y132.html
Fork Protectors - £20
- Supplied with fitting instructions
- Can be used as paddock stand bobbins
- Available in a variety of colours
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-518-y103.html
Swing Arm Protectors - £20
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-514-y111.html
Eliminator / Tail Tidy - £85
- Black textured finish
- LED number plate light included
- Reflector/Number plate support included
- All required fixings are supplied in the kit
- Can be used with OEM indicators or aftermarket ones
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-16-mt-09-tracer-fj-09-tracer-15-17-500-y110-003.html
Cooler Grill (Plastic) - £45
- Available in 6 colours
- Simple to fit
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-plastic-520-y121.html
Cooler Grill (Metal) - £45
- Available in textured black finish only
- Simple to fit
https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-520-y111.html
Powerblade (Adjustable Screen system) - £195
They are bike specific and simple to install. The design offers 2 ranges of movement. The screen angle can be adjusted back or forward. The height can be adjusted up and down allowing you to get the best setting for optimal riding comfort.
Each Powerblade comes with adjustable bracket assembly which includes bike specific mounting plate and 2 different height screens 1 at 455mm and the other 360mm.
Screens are available in Light Tint or Clear.
https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-17-fj-09-tracer-15-17-480-y104.html
Enter discount code UKFORUM1 to claim your 10% off at the cart page as shown in the screenshot below.
Free UK mainland delivery on orders over £100.
Please put a phone number on each order as it makes it easier to dispatch orders if they have a contact telephone number especially if they are going overseas.
Stay safe everyone.
All the best,
Richard
Edited by richardpb
