richardpb Posted October 2, 2020 Share Posted October 2, 2020 (edited) Hello Everyone, I hope your all well and staying safe under the current conditions ? Powerbronze have developed a range of products for the Tracer 900 2018+ model as follows (click the links below each product to view them individually on the site or click the link below to view the whole range): https://www.powerbronze.co.uk/catalogsearch/advanced/result/?finder_id=&from=category&cat_id=0&brand=YAMAHA&model=MT-09+TRACER&year=2019 All of these products have been designed and manufactured by Powerbronze at our factory in the UK. Beak - £95 - Available in Gloss Black, Gloss White and Matt Black finish - Made from high-impact ABS plastic - Supplied with all required fittings and full instructions https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-350-y105.html Flip Screen - £98 - Available in 16 colours - Made from 3 mm acrylic - 505 mm high x 335 mm wide https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-505-mm-420-y149.html Flip Screen - £98 - Available in 2 colours - Made from 4 mm acrylic - 580 mm high x 380 mm wide - Includes cutouts for hand guards https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-580-mm-60-mm-wider-420-y148.html Adventure Sport Screen - from £59 - Available in 17 colours - 310 mm high - Made from 3 mm acrylic https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-310-mm-460-y107.html Headlight Protectors - from £27 - Available in 14 colours - Clear, Light Tint and Yellow are road legal - Supplied with fitting kit and instructions. - Easy removal for cleaning https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-440-y557a.html Wind Deflectors - £40 - Available in 16 colours - Simple and easy to fit (direct replacements) https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-450-y104.html Mudguard Extender - £25 - Available in Gloss & Matt Black finishes - Made from high-impact ABS plastic - Fitment with screws or plastic rivets - All fittings supplied https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-650-y112.html Rear Hugger - from £99 - Available in Gloss Black, Matt Black & Carbon Look finishes - Made from high-impact ABS plastic - Simple to fit, no drilling - Supplied with full fitting kit and instructions - Use Posi-flex steel sleeved rubber mounting points to dampen vibration and avoid stress cracking - Exterior finish does not require painting and is UV protected to avoid sun damage https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-201-y112.html Belly Pan - £125 - Made from high-impact ABS plastic - Available in Gloss Black & Matt Black finishes with Silver meshed vents - Supplied with all required fittings and full instructions * Fits both Tracer 900 models (2015-2017 & 2018-2020) https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-19-fj-09-tracer-15-19-mt-09-tracer-gt-18-19-fj-09-tracer-gt-18-19-320-y118.html Belly Pan - £125 (Fits with Yamaha Engine Protectors) - Made from high-impact ABS plastic - Available in Gloss Black & Matt Black finishes with Silver meshed vents - Supplied with all required fittings and full instructions https://www.powerbronze.co.uk/yamaha-mt-09-tracer-15-19-mt-09-tracer-gt-18-19-fj-09-tracer-15-19-fj-09-tracer-gt-18-19-fits-with-yamaha-engine-protectors-320-y119.html Rear Mud Deflector - £35 Mud deflectors are designed to help reduce the amount of spray and debris being slung over the rear of your adventure bike. - Made from 4mm ABS - Simple and easy to fit https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-360-y101-070.html Crash Posts (Protectors) - 2 options for fitting positions (Front or Rear mount points) - Available in aerodynamic shaped high impact plastic - Available in anodised CNC machined finish - 13 colour options to compliment your bike - Removable end cap to hide engine mounting bolt - Designed and manufactured by Powerbronze in Great Britain Front Set - https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-16-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-front-set-513-y131.html Rear Set - https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-rear-set-513-y132.html Fork Protectors - £20 - Supplied with fitting instructions - Can be used as paddock stand bobbins - Available in a variety of colours https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-518-y103.html Swing Arm Protectors - £20 - Supplied with fitting instructions - Can be used as paddock stand bobbins - Available in a variety of colours https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-514-y111.html Eliminator / Tail Tidy - £95 - Black textured finish - LED number plate light included - Reflector/Number plate support included - All required fixings are supplied in the kit - Can be used with OEM indicators or aftermarket ones- Adjustable for use with or without panniers https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-for-use-with-panniers-500-y120-003.html Cooler Grill (Plastic) - £45 - Available in 6 colours - Simple to fit - Supplied with all required fittings and full instructions https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-plastic-520-y121.html Cooler Grill (Metal) - £45 - Available in textured black finish only - Simple to fit - Supplied with all required fittings and full instructions https://www.powerbronze.co.uk/yamaha-mt-09-fz-09-13-19-mt-09-tracer-fj-09-tracer-15-19-mt-09-tracer-gt-fj-09-tracer-gt-18-19-xsr900-16-19-520-y111.html Powerblade (Adjustable Screen system) - £195 They are bike specific and simple to install. The design offers 2 ranges of movement. The screen angle can be adjusted back or forward. The height can be adjusted up and down allowing you to get the best setting for optimal riding comfort. Each Powerblade comes with adjustable bracket assembly which includes bike specific mounting plate and 2 different height screens 1 at 455mm and the other 360mm. Screens are available in Light Tint or Clear. https://www.powerbronze.co.uk/yamaha-mt-09-tracer-18-19-mt-09-tracer-gt-18-19-fj-09-tracer-18-19-fj-09-tracer-gt-18-19-480-y101.html All products on this post qualify for Same day dispatch if order before midday (* in stock items only) Enter discount code UKFORUM1 to claim your 10% off at the cart page as shown in the screenshot below. Free UK mainland delivery on orders over £100. Please put a phone number on each order as it makes it easier to dispatch orders if they have a contact telephone number especially if they are going overseas. Stay safe everyone. All the best, Richard Edited October 2, 2020 by richardpb Link to comment Share on other sites More sharing options...
Butrzrulz Posted July 8, 2021 Share Posted July 8, 2021 I assume no US distributors? Link to comment Share on other sites More sharing options...
