Aras Posted November 1, 2020 Share Posted November 1, 2020 (edited) Hello I want an answer Fog lights for a motorcycle. Question, can I do it right? -- - Switch Led 12v and 3A - Halogens 2 x 10W 12v Max Lum 2 Lampa The harness from the motorcycle has an output for additional accessories protected by a 2A fuse Whether to go to the relay test or go to the installation. The motorcycle has a balanced 4 outlets for accessories are already in addition - - USB 12v - Voltometer - halogens - here I want to start as above Max-Lum 2, pair of led fog lights, 12V Diecast aluminium... Edited November 1, 2020 by Aras Link to comment Share on other sites More sharing options...
BBB Posted November 1, 2020 Share Posted November 1, 2020 If the lamps are 10W for the pair, then they only use 0.8A. If it’s 20W across two lamps you are still only using 1.7A so the auxiliary circuits should cope easily. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Aras Posted November 1, 2020 Author Share Posted November 1, 2020 15 minutes ago, BBB said: If the lamps are 10W for the pair, then they only use 0.8A. If it’s 20W across two lamps you are still only using 1.7A so the auxiliary circuits should cope easily. switch 3A will be ok? Link to comment Share on other sites More sharing options...
BBB Posted November 1, 2020 Share Posted November 1, 2020 A 3A switch will be fine. The fuse for the circuit is 2 A, which will also be fine. Red 2015 Tracer, UK spec (well, it was until I started messing with it...) Link to comment Share on other sites More sharing options...
Aras Posted November 1, 2020 Author Share Posted November 1, 2020 Thank you 😉 Link to comment Share on other sites More sharing options...
alexreinke Posted November 1, 2020 Share Posted November 1, 2020 1 hour ago, Aras said: switch 3A will be ok? where did you get that switch, its great Link to comment Share on other sites More sharing options...
Aras Posted November 1, 2020 Author Share Posted November 1, 2020 (edited) 34 minutes ago, alexreinke said: where did you get that switch, its great 6,09 zł 25% zniżki | Elektryczna wodoodporna moc 12v Led Light chwilowy czarny przełącznik wciskany 8/10/12/16/19/22mm przełączniki ciśnieniowe 220v Aluminiumhttps://a.aliexpress.com/_BVegmW 12mm black Lathing Fixing color Green Edited November 1, 2020 by Aras Link to comment Share on other sites More sharing options...
dan77 Posted March 16 Share Posted March 16 On 11/1/2020 at 11:42 AM, Aras said: 6,09 zł 25% zniżki | Elektryczna wodoodporna moc 12v Led Light chwilowy czarny przełącznik wciskany 8/10/12/16/19/22mm przełączniki ciśnieniowe 220v Aluminiumhttps://a.aliexpress.com/_BVegmW 12mm black Lathing Fixing color Green Hi @Aras I'm trying to install a button like this one please could you share how you did? Link to comment Share on other sites More sharing options...
