Oddjob Posted November 2, 2020 Share Posted November 2, 2020 (edited) Hey all, as stated in the title apparently no maintenance has been done except for oil changes and tires. I took a look at the service schedule, which is pretty extensive, but I wanted to ask everyone here: What things most definitely would and/or should be done now that its in my possession? It seems to be in great shape, rides fantastic. I've done some basic work on an older 1983 Honda Nighthawk, but I'm no pro and I will be taking it to a mechanic for a good look over. But the only glaring thing I found myself is that the chain needs to be cleaned and probably adjusted as well. Many thanks in advance, glad to be here! Edited November 2, 2020 by Oddjob Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted November 2, 2020 Premium Member Share Posted November 2, 2020 By mileage, not much. Throttle body sync, maybe? By age, brake fluid and coolant. 2nd gen clutch cable. Make sure all of the recalls were done - CCT and handlebars off the top of my head. 2 Link to comment Share on other sites More sharing options...
Ride365 Posted November 2, 2020 Share Posted November 2, 2020 Maintenance most certainly isn’t extensive on these bikes, matter of fact you have the major service at 24k miles but up to that “realistically” that’s about it other than perhaps brake fluid flush and refill. Keep it all simple stupid, mind your chain and stay up on fluid changes.....ride the hell out of it. Others might disagree with me, but hey that’s how I approach it is all, plenty in service or user manual which is so overkill imho. 4 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 2, 2020 Supporting Member Share Posted November 2, 2020 Over the winter, pull the swingarm and shock linkage apart and clean and grease all of the bearings. You can carefully pry off the dust seals and grease the wheel bearings as well. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Oddjob Posted November 2, 2020 Author Share Posted November 2, 2020 1moreroad - He did say he had it in for a recall work shortly after he purchased it(new) and a search by vin indicates that there are no outstanding recalls on the bike. Ride365 - Right on, that seems to be the word on the street that Yamaha's are tanks and don't need a whole lot. Looking at the schedule right off the bat to me it seemed like they're just trying to get you in the shop, and I've seen mechanics say the same thing. betoney - Good to know, is that something that's good to do annually? Thanks for all the replies! 1 Link to comment Share on other sites More sharing options...
peteinpa Posted November 2, 2020 Share Posted November 2, 2020 Do the oil drain bolt mod. very important. Read the whole garage section and do those mods. 2 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 2, 2020 Supporting Member Share Posted November 2, 2020 12 hours ago, Oddjob said: betoney - Good to know, is that something that's good to do annually? Personally, I do it annually. Once you do it the first time, it’s a fairly simple process. If you ride in the rain, it’s a no-brainer. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Oddjob Posted November 3, 2020 Author Share Posted November 3, 2020 Just looked into the bolt mod, oof. Seems like the right move! 1 Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 4, 2020 Premium Member Share Posted November 4, 2020 On 11/1/2020 at 10:57 PM, betoney said: You can carefully pry off the dust seals and grease the wheel bearings as well. I don't know if I'd go through that trouble. I'm pushing 100K and my wheel bearings are still smooth as butter. 1 Let’s go Brandon Link to comment Share on other sites More sharing options...
koth442 Posted November 4, 2020 Share Posted November 4, 2020 I would have the valves checked. Otherwise, I'd say you're all good! 1 '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member fjray Posted January 31, 2021 Premium Member Share Posted January 31, 2021 Why so early on the valves? And who in their right minds takes the plugs out and cleans them in 4K miles? Link to comment Share on other sites More sharing options...
peteinpa Posted January 31, 2021 Share Posted January 31, 2021 Mine is sitting in the basement right now completely apart and I'm fighting the urge to check the valves at 4k miles. I'll wait till next winter though and do it at what ever mileage is on it then. This engine has displayed a history of the exhaust valve clearance getting too tight at a much lower mileage than the first scheduled check of 26k miles. Leave it alone and it will cost you $1500 min. for a head job. I'll be checking mine at well under 16k miles the first time and then no more than an additional 16k miles till it settles down (if it does). Link to comment Share on other sites More sharing options...
