Premium Member fr8dog Posted November 16, 2020 Premium Member Share Posted November 16, 2020 I have a new rotor and bolts on order. Won't be here for a few weeks. I had the rear tire off doing other stuff and tried to remove one of the bolts just to see how tight they were. The bolts are on there pretty good. I couldn't loosen it up. Didn't want to risk stripping it. Any ideas? Impact driver? Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 16, 2020 Supporting Member Share Posted November 16, 2020 52 minutes ago, fr8dog said: Any ideas? Impact driver? Use heat prior to attempting to remove them. They have thread locker from the factory. Smart idea that you have new bolts, you might ruin the heads on 1 or 2 of them. 1 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted November 16, 2020 Supporting Member Share Posted November 16, 2020 25 minutes ago, betoney said: Use heat prior to attempting to remove them. They have thread locker from the factory. 100 percent this. Liberal use of the heat gun, then smooth steady pressure to break them loose. I used a long breaker bar (instead of an impact) on the front rotor bolts, and it worked like a champ. 2 Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 16, 2020 Premium Member Share Posted November 16, 2020 X 3 on the heat Let’s go Brandon Link to comment Share on other sites More sharing options...
koth442 Posted November 16, 2020 Share Posted November 16, 2020 Heat. I prefer Bernzo-matic. Then drop your allen in there, make sure it's well seated all the way down. You shouldn't strip it if it's well seated and not previously rounded. They are very tight though. 1 '15 FJ09 Link to comment Share on other sites More sharing options...
Premium Member fr8dog Posted November 17, 2020 Author Premium Member Share Posted November 17, 2020 Thanks for the help. Bernzomatic it is! 1 Link to comment Share on other sites More sharing options...
Premium Member micah2074 Posted November 17, 2020 Premium Member Share Posted November 17, 2020 17 hours ago, koth442 said: Heat. I prefer Bernzo-matic. Then drop your allen in there, make sure it's well seated all the way down. You shouldn't strip it if it's well seated and not previously rounded. They are very tight though. This. I’ve never stripped one. 1 Let’s go Brandon Link to comment Share on other sites More sharing options...
