Bimbim18 Posted November 21, 2020 Share Posted November 21, 2020 My handguard brackets and mirror stems are rusting pretty bad. I want to take it all apart and sand and paint. Anyone know how to do this? From looking at it I especially can't tell how to remove the mirror from the stem. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 21, 2020 Supporting Member Share Posted November 21, 2020 30 minutes ago, Bimbim18 said: My handguard brackets and mirror stems are rusting pretty bad. I want to take it all apart and sand and paint. Anyone know how to do this? From looking at it I especially can't tell how to remove the mirror from the stem. Are you talking about the upper adjustable portion of the mirror? or the lower part that threads into the mount? There is the lower part that screws into the mount on the handlebar the then there is a rubber boot that slides up where you can install a mirror extender. If you are wanting to actually remove the mirror itself from the stem, I have no idea how that tightens or loosens. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Bimbim18 Posted November 21, 2020 Author Share Posted November 21, 2020 Yeah, I want to disassemble it completely. The upper aluminum cone shaped things are corroding too, so I want to remove that so I can get a good paint and prime on that as well as the rod that holds the mirrors. Link to comment Share on other sites More sharing options...
