Shizzle Posted November 28, 2020 Share Posted November 28, 2020 Looking to replace the Stock Pumpkin turn signals on my 2020 GT. What are you guys using? Link to comment Share on other sites More sharing options...
roy826 Posted November 28, 2020 Share Posted November 28, 2020 (edited) Cyclops I’ve been In contact with them. He said the T7 specific kit should work. I have a T7 with the kit and I think the wire leads will come up short on the GT. Easy fix with wire, soldering gun and heat shrink though. It’s plug and play on the T7. Edited November 28, 2020 by roy826 Link to comment Share on other sites More sharing options...
roy826 Posted November 28, 2020 Share Posted November 28, 2020 (edited) Picture of my T7 which had the same big pumpkin ugly yamaha issue signals. This is the Cyclops which is white on DRL and you tap postitap rear brake light wire for a light show when you hit the brakes on the rear. Edited November 28, 2020 by roy826 2 Link to comment Share on other sites More sharing options...
Clicknow Posted November 28, 2020 Share Posted November 28, 2020 These work great very bright and look good. https://www.oxfordproducts.com/motorcycle/brands/oxford/lighting/nightrider_streaming_indicators_incl_2_resistors/ Link to comment Share on other sites More sharing options...
Ride365 Posted November 28, 2020 Share Posted November 28, 2020 9 hours ago, Clicknow said: These work great very bright and look good. https://www.oxfordproducts.com/motorcycle/brands/oxford/lighting/nightrider_streaming_indicators_incl_2_resistors/ Do they also function as running lights as well? Link to comment Share on other sites More sharing options...
Clicknow Posted November 28, 2020 Share Posted November 28, 2020 No just the signal regards Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 28, 2020 Supporting Member Share Posted November 28, 2020 13 hours ago, Shizzle said: Looking to replace the Stock Pumpkin turn signals on my 2020 GT. What are you guys using? I use the X-Arc signals front and rear. Small, strong (billet aluminum) and STUPID BRIGHT. They ARE wired for running lights if used on the front. X-Arc Lights - the brightest LED Brake lights, turn signals, tail lights 3 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Ride365 Posted November 28, 2020 Share Posted November 28, 2020 They are stupid expensive too, but may just pull the trigger on some eventually. 1 Link to comment Share on other sites More sharing options...
Premium Member 1moreroad Posted November 28, 2020 Premium Member Share Posted November 28, 2020 5 hours ago, betoney said: I use the X-Arc signals front and rear. Small, strong (billet aluminum) and STUPID BRIGHT. They ARE wired for running lights if used on the front. X-Arc Lights - the brightest LED Brake lights, turn signals, tail lights Same seller, Proton 500 Stupid bright. Illuminate ground, sides, and forward. Running lights and blinkers. Programmable blink pattern. Plug and play. I bought them here: Tripageled Proton 500 2 Link to comment Share on other sites More sharing options...
Shizzle Posted November 28, 2020 Author Share Posted November 28, 2020 I wouldn't mind just having some clear lenses but I'm guessing that's not an option. Link to comment Share on other sites More sharing options...
GTO MIKE Posted November 29, 2020 Share Posted November 29, 2020 Also looking for replacements. Not only do the stockers look ugly, but are so floppy flexible. Just looking at options MIKE! Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted November 29, 2020 Supporting Member Share Posted November 29, 2020 1 hour ago, Shizzle said: I wouldn't mind just having some clear lenses but I'm guessing that's not an option. You used to be able to find them regularly on Ebay but I cant find them anymore. I 'believe' the European and Australian models have clear lenses? (can anyone confirm this?) if so, you might be able to buy oem signals from Europe. These 'might' work but possibly not oem quality. 2pcs Clear Front Turn Signals Cover Lens Shell for Yamaha YZF R1 R6 R6S FZ1 FZ6 Yamaha FZ6 2004-2009. Yamaha YZF R1 2009-2010. Yamaha R6... ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Manxkiwi Posted November 29, 2020 Share Posted November 29, 2020 Yep, clear lenses in NZ. (Also unpainted pannier lids, which is a bit disappointing!) 1 Link to comment Share on other sites More sharing options...
PhotoAl Posted November 29, 2020 Share Posted November 29, 2020 4 hours ago, 1moreroad said: Same seller, Proton 500 Stupid bright. Illuminate ground, sides, and forward. Running lights and blinkers. Programmable blink pattern. Plug and play. I bought them here: Tripageled Proton 500 Had these or something similar on my CBR600RR. Really liked them - good visibility from the side as well as straight on. Like the brightness of the X-Arc lights though. For the rear planning on mounting a couple of strips on the back of the side cases. One for brake and tail lights and another for turn signals. Still in the contemplation stage. Have the strips from Amazon and they look nice and seem to be bright. Biggest hassle with putting them on the side cases is have to add connectors so side cases can be removed. 1 Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted November 29, 2020 Premium Member Share Posted November 29, 2020 IMO bigger is better as is bang for the buck To that end I replaced all four turn signals with LED "bulbs" and replaced the OEM blinker relay with a low load unit I ran a running light wire in the rear so all four are running / turn signals which is technically illegal in the rear you should have red haven't been stopped in many years doing that on other bikes OEM Pumpkins are seasonal but they do provide good side / front / rear illumination I of course got a spare set of fronts and spliced them into the rear Loom adding the running light wire and plugged everything in like OEM Running auxiliary brake lights side marker lights driving lights headlight modulator reflective tape including on the wheels are part of the scheme here if you haven't caught that already 😎 Link to comment Share on other sites More sharing options...
