Yamajank Posted December 14, 2020 Share Posted December 14, 2020 18 hours ago, Heli ATP said: Can we see a pic of the back with the wires etc. I added PowerBronze handguard extenders to my FJ and would consider a project like yours. Nice Job! The pic shows the stock and replacement PowerBronze handguards. I now have more real estate to work with. ☺️ I think this is what you were asking for. 2 Link to comment Share on other sites More sharing options...
Supporting Member Heli ATP Posted December 14, 2020 Supporting Member Share Posted December 14, 2020 Thanks, that looks easy enough. Link to comment Share on other sites More sharing options...
Shizzle Posted December 15, 2020 Author Share Posted December 15, 2020 I have kinda given up on this LED turn signal quest. I have ordered 3 sets and they are all crap. Hard to find one with the running light for the front that isn't Chinese crap. The search continues. I will keep my TST relay, signal adapters and wire adapters in hopes I will find something decent. But for now I will wait. Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted December 15, 2020 Supporting Member Share Posted December 15, 2020 33 minutes ago, Shizzle said: I have kinda given up on this LED turn signal quest. I have ordered 3 sets and they are all crap. Hard to find one with the running light for the front that isn't Chinese crap. The search continues. I will keep my TST relay, signal adapters and wire adapters in hopes I will find something decent. But for now I will wait. If you want high quality, BRIGHT signals, you could look at the ones I recommended at the beginning of this thread. Billet aluminum (nearly indestructible) compact and ridiculously bright. I use these on both front and back and they DO have running light capability. X-Arc Lights - the brightest LED Brake lights, turn signals, tail lights 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted December 16, 2020 Premium Member Share Posted December 16, 2020 or the cheap and I used the 3-wire LED "bulb" all around with 2 used OEM front TS/RL ($12 shipped) in the rear with my own longer adapter wiring soldered together for the rear TS/RL RL wires spliced into the tail light supply leads, with a $7 low-load LED relay I just had to swap the pins in the plug for plug n' play to the OEM flasher relay plug. Still have bright pumpkins but with the side panel running lights, twin 18w led driving lights & HLM I'm SEEN! A X-Blaster Tail Light is going in this winter... 1 Link to comment Share on other sites More sharing options...
roadwarrior Posted December 16, 2020 Share Posted December 16, 2020 I went with the Super Tenere blinkers. I believe these are now also the stock blinkers on the 2021 Tracer as they should have been all along! Perfect fit and goes well with the bike. 3 1 Link to comment Share on other sites More sharing options...
Shizzle Posted December 16, 2020 Author Share Posted December 16, 2020 2 minutes ago, roadwarrior said: I went with the Super Tenere blinkers. I believe these are now also the stock blinkers on the 2021 Tracer as they should have been all along! Perfect fit and goes well with the bike. Those look great. Where did you get them? Link to comment Share on other sites More sharing options...
roadwarrior Posted December 16, 2020 Share Posted December 16, 2020 (edited) 11 minutes ago, Shizzle said: Those look great. Where did you get them? There is a nice write up including part numbers and websites here. For the back I used the the Motodynamic Fender Eliminator and Integrated Tail Light. Edited December 16, 2020 by roadwarrior 2 Link to comment Share on other sites More sharing options...
Clem Fandango Posted December 16, 2020 Share Posted December 16, 2020 20 hours ago, Shizzle said: I have kinda given up on this LED turn signal quest. I have ordered 3 sets and they are all crap. Hard to find one with the running light for the front that isn't Chinese crap. The search continues. I will keep my TST relay, signal adapters and wire adapters in hopes I will find something decent. But for now I will wait. 12oclocklabs. Plenty bright, retains running lights if you want. They're not Rizomas, but certainly not cheap crap either. Link to comment Share on other sites More sharing options...
Ddog gt Posted December 19, 2020 Share Posted December 19, 2020 Yamajank Where did you splice into the wiring for the handguard lights? Also any other tips to help keep me out of trouble. thanks Link to comment Share on other sites More sharing options...
Yamajank Posted December 19, 2020 Share Posted December 19, 2020 (edited) 12 hours ago, Ddog gt said: Yamajank Where did you splice into the wiring for the handguard lights? Also any other tips to help keep me out of trouble. thanks Inside the second side panel area (as you’re removing pieces). I actually drilled a small hole in the back of the black plastic piece for that wire to go through. Then pigtails. The right side has a lot less slack than the left side, so less room for error. It all tucked away nicely though once all the connections were made. I believe the blue wires are the running light wires. Lots of little pins and screws so if you’ll have it apart for a while I suggest to take some pics. I actually have the original 3 pin connector going to those hand guards and made new connectors for the turn signals, otherwise you probably wouldn’t need to drill a hole, but it’s all hidden anyway. Edited December 19, 2020 by Yamajank Link to comment Share on other sites More sharing options...
Ddog gt Posted December 23, 2020 Share Posted December 23, 2020 Does anyone know where to source the Tanshi.040 Male Turn Signal Connector? thanks in Advance. Link to comment Share on other sites More sharing options...
Shizzle Posted December 23, 2020 Author Share Posted December 23, 2020 1 hour ago, Ddog gt said: Does anyone know where to source the Tanshi.040 Male Turn Signal Connector? thanks in Advance. Yamaha NT-040 Motorcycle Turn Signal Connectors Nippon Tanshi NT-040 Motorcycle Turn Signal Connectors. Commonly... Link to comment Share on other sites More sharing options...
Ddog gt Posted December 23, 2020 Share Posted December 23, 2020 Thanks, Shizzle, I forgot I had this site bookmarked, have not used it in a long time. God getting old sucks. First your memory goes then something else, but I can’t remember what. 2 1 Link to comment Share on other sites More sharing options...
thewrenchbender Posted December 23, 2020 Share Posted December 23, 2020 Smoke-tested the Cyclops provided relay and completed splicing in the T700 rear adaptor cables (eliminated the bullet connectors) & installing the rear blinkers. Still need to posi tap in the brake signal. Have the front cheek panels split but have gotten temporarily interrupted to go grocery shopping.... 1 Link to comment Share on other sites More sharing options...
