Jackson Posted January 12, 2021 Share Posted January 12, 2021 Yamajank, thanks for this information. I may just order a pair as I don’t like the way that most lights stick out from the fairings. I’ve just received delivery of a very small pair of lights to replace the pumpkins. I haven’t installed them yet, but they seem good quality and are quite bright. I chose the black ones with clear lenses. You can see them here: https://www.aliexpress.com/item/1005001364737067.html?spm=a2g0o.productlist.0.0.30be5014BDozUg&algo_pvid=cead24b3-2656-477c-bd08-5632fb7c8fe3&algo_expid=cead24b3-2656-477c-bd08-5632fb7c8fe3-0&btsid=0bb0623916104232795371088e02a1&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Like you, I am concerned about the visibility of small lights in the stock locations. I may get LED strips for the hand guards which will have white lights for the daytime running lights and amber for the turn signals. I’m thinking about ordering these ones: https://www.ebay.ca/itm/2x-LED-Motorcycle-Turn-Signals-Flexible-Strip-Blinkers-Amber-White-Tail-Light-/223942802046 They may not be as elegant as your solution, but should be very visible. Good luck with your project. 1 Link to comment Share on other sites More sharing options...
Samaha Posted April 16, 2021 Share Posted April 16, 2021 (edited) After finding a pair of old protons that were scratched up from a tip over, I decided to sand down the lenses and repurpose them to replace my rear stock signals. First, I took apart the stockers and snipped the wires close to the bulbs. Next I used the stock base and mounted L brackets to attach the old protons to my aftermarket fender eliminator. Finally I re-connected the stock wire to the proton lights and plugged them back in under the seat. I love that the lights are extremely bright. Edited April 16, 2021 by Samaha typo 1 Link to comment Share on other sites More sharing options...
Samaha Posted April 19, 2021 Share Posted April 19, 2021 Another satisfied customer. The TST 2 PIN LED FLASHER RELAY GEN 2 worked like a charm. It took 2 minutes to replace the OEM relay which is located under the rider seat as shown below. Link to comment Share on other sites More sharing options...
Samaha Posted April 21, 2021 Share Posted April 21, 2021 (edited) I just replaced my front stock signals with Proton 500's. Rather than explaining I included pics. I love the lights. Edited April 21, 2021 by Samaha 2 1 Link to comment Share on other sites More sharing options...
Torbeach Posted April 21, 2021 Share Posted April 21, 2021 Do you have any tips for separating the inner panel from the outer panel without breaking the tabs trying to remove the toothed washers? Link to comment Share on other sites More sharing options...
Samaha Posted April 21, 2021 Share Posted April 21, 2021 2 hours ago, Torbeach said: Do you have any tips for separating the inner panel from the outer panel without breaking the tabs trying to remove the toothed washers? Honestly, i just used a flat head screwdriver and slowly pried them off. Don't be afraid to bend the toothed washers when removing. I then flattened the washers with a pair of pliers and re-used them. 2 Link to comment Share on other sites More sharing options...
CJ3cyl Posted April 22, 2021 Share Posted April 22, 2021 (edited) Check out the OEM turn signals from the 2021 MT07. $33 a piece from Ron Ayers. That's the route I'm going. Edited April 22, 2021 by CJ3cyl add pic 6 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 22, 2021 Supporting Member Share Posted April 22, 2021 33 minutes ago, CJ3cyl said: Check out the OEM turn signals from the 2021 MT07. $33 a piece from Ron Ayers. That's the route I'm going. I would think that signals from the MT07 as well as MT09 and SP and Tracer 9 will all work, they all look to be identical for 2021. 1 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted April 22, 2021 Supporting Member Share Posted April 22, 2021 43 minutes ago, CJ3cyl said: Check out the OEM turn signals from the 2021 MT07. $33 a piece from Ron Ayers. That's the route I'm going. I did the factory Super Tenere LED signals on my FJ a few years ago, and suffice it to say that they were MUCH more than $33 a piece. Assuming those MT07 signals work, that looks like a fantastic way to go... Keep us posted on your progress. Link to comment Share on other sites More sharing options...
CJ3cyl Posted April 22, 2021 Share Posted April 22, 2021 12 minutes ago, texscottyd said: I did the factory Super Tenere LED signals on my FJ a few years ago, and suffice it to say that they were MUCH more than $33 a piece. Assuming those MT07 signals work, that looks like a fantastic way to go... Keep us posted on your progress. Will do. Link to comment Share on other sites More sharing options...
ODiE Posted May 21, 2021 Share Posted May 21, 2021 @Samaha did those plug right in to the stock connector? Link to comment Share on other sites More sharing options...
Samaha Posted May 21, 2021 Share Posted May 21, 2021 6 minutes ago, ODiE said: @Samaha did those plug right in to the stock connector? Yes, perfectly. i have the 2020 Tracer 900 GT Link to comment Share on other sites More sharing options...
fjrpittsburgh Posted May 31, 2021 Share Posted May 31, 2021 (edited) On 4/22/2021 at 9:26 AM, CJ3cyl said: Check out the OEM turn signals from the 2021 MT07. $33 a piece from Ron Ayers. That's the route I'm going. @CJ3cyl Are the 2021 MT-07 LED front turn signals also running lights? Edited May 31, 2021 by fjrpittsburgh Link to comment Share on other sites More sharing options...
CJ3cyl Posted June 4, 2021 Share Posted June 4, 2021 I believe so. The signals are on back order, though. I haven't even received them yet. Link to comment Share on other sites More sharing options...
Clegg78 Posted June 4, 2021 Share Posted June 4, 2021 https://www.tracer900.net/topic/6642-official-all-encompassing-flasher-led-thread/?do=findComment&comment=127742 I posted my led signal install from a few months ago in another thread. I just put 1600 miles on them last week and they worked great. They are more visible than I would have expected from small strips. They riding lights and brake light features are nice as well. Link to comment Share on other sites More sharing options...
