kenvieri Posted April 9, 2021 Author Share Posted April 9, 2021 17 hours ago, betoney said: When you buy this specific kit, it comes with everything you need for the conversion. There was a thread on here a few years ago on the process and steps to swap the parts. As a note - you do have to swap some of the original clutch plates for this specific conversion. Thanks for the tips! 1 Link to comment Share on other sites More sharing options...
kenvieri Posted April 9, 2021 Author Share Posted April 9, 2021 7 hours ago, dazzler24 said: Without me looking those part numbers up, if they are the 'newer' clutch cover and rubber sound damper then the answer is not necessarily. I did the slipper clutch install on my 2015 and kept my original clutch cover. No issues to report. BTW - You'll like the end result if you go ahead with the slipper install. 🙂 Can't wait anymore!!!😁 1 1 Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 9, 2021 Supporting Member Share Posted April 9, 2021 30 minutes ago, kenvieri said: Can't wait anymore!!!😁 NIKE - Just do it! Certainly worth putting in the effort in my very humble opinion and experience. Major benefits IMHO are: - Soft clutch lever pull Forgiving downshift at pace Reduced rear wheel chatter - see forgiving downshift. Something you can do yourself, feel good about and do it at a reasonable price (YMMV) 🙂 2 Link to comment Share on other sites More sharing options...
kenvieri Posted May 30, 2021 Author Share Posted May 30, 2021 (edited) It's been about one month since I order the parts form partshark......does anyone know how long it takes?😪😪😪 Shipment Received, Package Acceptance Pending May 4, 2021 at 4:08 pm INDIANAPOLIS, IN 46206 Edited May 30, 2021 by kenvieri Link to comment Share on other sites More sharing options...
DubT9 Posted June 6, 2021 Share Posted June 6, 2021 On 5/30/2021 at 9:49 PM, kenvieri said: It's been about one month since I order the parts form partshark......does anyone know how long it takes?😪😪😪 Shipment Received, Package Acceptance Pending May 4, 2021 at 4:08 pm INDIANAPOLIS, IN 46206 I received the kit on Friday, from order to delivery to Ireland was about 9 days but only took 5 days from the shipping notification. Looking forward to this upgrade. 1 Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted June 6, 2021 Premium Member Share Posted June 6, 2021 Let us know how it goes, truly hope it solves your problem. 1 Link to comment Share on other sites More sharing options...
kenvieri Posted June 8, 2021 Author Share Posted June 8, 2021 I got the package finally!!! I'll give you all a report after installing it asap. 1 1 Link to comment Share on other sites More sharing options...
skipperT Posted June 9, 2021 Share Posted June 9, 2021 5 hours ago, kenvieri said: I got the package finally!!! I'll give you all a report after installing it asap. Great! Make sure you soak those friction plates in some fresh oil for min. 30 minutes before installing. -S Link to comment Share on other sites More sharing options...
kenvieri Posted June 9, 2021 Author Share Posted June 9, 2021 Since I got the problem, I replaced the spark plug, engine oil, clean the air filter, and the problem still remained, so I decide to replace the coil and the clutch. I order the clutch kit and the coil from partshark on the early of May, and I received it on 2021-06-07, and I am living in Hong Kong.👿😤 After viewing the video on youtube, it is quite simple to conduct the replacement. And now, I feel the clutch level is lighter than the original one for a lot!!!😲😲😲 The engagement of clutch is precise. The noise from the clutch also disappear. The main point is, the problem was solved!!!✌️ I'll keep update you guys after replacing the clutch, I hope the problem never happen again.😁 1 Link to comment Share on other sites More sharing options...
kenvieri Posted June 9, 2021 Author Share Posted June 9, 2021 5 minutes ago, skipperT said: Great! Make sure you soak those friction plates in some fresh oil for min. 30 minutes before installing. -S I soak it overnight~✌️ 1 Link to comment Share on other sites More sharing options...
