Danielblue Posted April 12, 2021 Share Posted April 12, 2021 (edited) Just got a quicklock (Quadlock) mount and set it up in the middle of the handlebar on a 2019 Tracer, fits perfectly and out of the way. Also got a usb charger for the aux on the left side. Does anyone know of a short USB to lightning connector cord that would hold up well and reach without being all over the place? Edited April 25, 2021 by Danielblue added brandname Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted April 12, 2021 Supporting Member Share Posted April 12, 2021 I’ve been using a Titan Power cable for a couple of years on the FJ, and so far it’s held up well. The 90 degree cable end is really helpful to avoid interference with the plastic trim around the fuel tank. I have the 18” length, and use the same setup you have: USB outlet left of the dash, and iPhone dead center on the bars between the clamps. I usually just make one loop around the bars between the clamps, and the length works perfectly. The Titan Smart Cable™ Avoid frustration from broken iPhone... Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted April 12, 2021 Premium Member Share Posted April 12, 2021 In my experience using the OEM cigarette power plug can be a failure prone. I installed a dual QC 3.0 2.5 A USB / Volt Meter in the unused right bracket (you need to enlarge the hole slightly) as back-up with a USB cable, and use a RAM X-Grip type mount with a hard wired power supply that comes with waterproof USB cables. Or if you have a SAE plug to your battery you can use one of these. 12-24V Motorcycle Cell Phone QC3.0 Dual USB Fast Charger+Voltmeter+On/Off Switch Range of use: It can be used on vehicles, motorcycles, ATVs... 5V 4.2A Dual USB Charger Socket Adapter Power Outlet for 12V 24V Motorcycle Car Motorcycle Cover waterproof Heavy Duty for Winter Outside... I can't find the X-grip mount with separate power supply I use on the FJ but use this on one of my other bikes. They keep my Galaxy S21 fully charged using waze and music. Motorcycle Handlebar Mirrors Cell Phone Mount Holder & USB Charger For Suzuki - Compatible Devices for All kind of Smart Phone with 3.5-6... Link to comment Share on other sites More sharing options...
Danielblue Posted April 13, 2021 Author Share Posted April 13, 2021 Thanks and Thanks :) Link to comment Share on other sites More sharing options...
