Premium Member keithu Posted April 25, 2021 Premium Member Share Posted April 25, 2021 During a nice but brisk ride this morning I discovered my heated jacket liner didn't work. Back home I started to troubleshoot this, and discovered something slightly alarming: It appears my clutch cable has been rubbing on the wiring harness connected to the bottom of the ignition key switch. Here you can see how the clutch cable has rubbed the black finish off the ignition switch housing, and it appears to have abraded the sheath on the wiring harness. Note the exposed wiring showing through the sheathing. The wires and insulation appear to be okay, but turning the handlebars back and forth confirmed that the clutch cable does rub the wiring harness at full left steering lock. To resolve this issue, I wrapped a heavy duty zip tie loosely around the clutch cable and part of the triple clamp. I turned the steering lock to lock a few times and confirmed that nothing interferes or is restricted. As you can see I have the new style of clutch cable. I believe it's routed correctly, but I'm open to other opinions about that. Next time you have your bodywork off, I advise you to inspect the ignition wiring to ensure the clutch cable isn't damaging it. Here's an obligatory shot from my ride this morning. I don't know what that bright yellow stuff is, but I've seen it in a few fields around the Willamette Valley this week. 4 2 Link to comment Share on other sites More sharing options...
peteinpa Posted April 25, 2021 Share Posted April 25, 2021 Jeez you tell me this just as I reassembled it for the millionth time! 😠🤣 1 Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted April 26, 2021 Supporting Member Share Posted April 26, 2021 Appreciate the heads-up. I will definitely give mine an inspection. ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Supporting Member dazzler24 Posted April 26, 2021 Supporting Member Share Posted April 26, 2021 Likewise. Thanks. Link to comment Share on other sites More sharing options...
Scoti Posted April 26, 2021 Share Posted April 26, 2021 That yellow stuff would be Canola (used in margarines and cooking oils ) ,or daisy weeds used for nothing . 1 Link to comment Share on other sites More sharing options...
skipperT Posted April 26, 2021 Share Posted April 26, 2021 Yes, here too. I used a strip of black electrical tape to protect the harness. Clutch cable was replaced couple years ago. -Skip 1 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted April 26, 2021 Author Premium Member Share Posted April 26, 2021 9 hours ago, Scoti said: That yellow stuff would be Canola (used in margarines and cooking oils ) ,or daisy weeds used for nothing . Interesting, I didn't know anyone was growing canola around here. I thought all that stuff came from Canada. Link to comment Share on other sites More sharing options...
roy826 Posted April 26, 2021 Share Posted April 26, 2021 I just took a peek at my 2020 and it doesn't look like that setup. Cable hots only the bottom of that ignition/whatever it is but no where near the wires. 2 Link to comment Share on other sites More sharing options...
Premium Member keithu Posted April 26, 2021 Author Premium Member Share Posted April 26, 2021 3 hours ago, roy826 said: I just took a peek at my 2020 and it doesn't look like that setup. Good info. I should have noted that mine is a 2015 model. Link to comment Share on other sites More sharing options...
Supporting Member piotrek Posted April 26, 2021 Supporting Member Share Posted April 26, 2021 I found a tiny bit of wear in that location (2015). Preventative measures in the works. Thanks. Link to comment Share on other sites More sharing options...
roy826 Posted April 26, 2021 Share Posted April 26, 2021 2 hours ago, keithu said: Good info. I should have noted that mine is a 2015 model. No problem I’m the idiot didn’t see that part lol either way I’m always grateful for little detailed things like this. My 2016 Suzuki GSX-S1000 had a issue with rubbing on the clutch cable against a sharp top edge of the radiator. Zip tie solves that issue. 1 Link to comment Share on other sites More sharing options...
Heavy Posted December 9, 2023 Share Posted December 9, 2023 (edited) On 4/26/2021 at 12:24 PM, keithu said: Interesting, I didn't know anyone was growing canola around here. I thought all that stuff came from Canada. Can't blame us for all of it. A fair bit grown in the US. ; ) Edited December 9, 2023 by Heavy There is never enough time or money to do it right the first time. Link to comment Share on other sites More sharing options...
Ride365 Posted December 9, 2023 Share Posted December 9, 2023 I've seen that here in Ohio, now I know what it is......thanks! Link to comment Share on other sites More sharing options...
