xlxr Posted June 15, 2016 Share Posted June 15, 2016 Stick around a bit longer, we will get you to sell off those BMW and Harley things. You just won't need them any more. Link to comment Share on other sites More sharing options...
timg Posted June 15, 2016 Share Posted June 15, 2016 The dog bone links on shock linkage on my bike were way too tight and loosening them softened up the rear enough to feel it. These should be tightening onto bushings and bearings, providing clearance between the arms and the struts to which they connect. So "loosening" the bolts should not change their pivoting force, and is defeating the reason for the original torque requirement on these fasteners. If there is not clearance when they are tight then something is wrong and this should be addressed by a qualified mechanic. Not having the correct torque on these nuts could result in a dangerous situation over time, as they may loosen further and eventually back off entirely. Link to comment Share on other sites More sharing options...
xlxr Posted June 16, 2016 Share Posted June 16, 2016 That's the theory, but the factory mechanic over-tightened mine so much they were binding up. I agree that too loose can cause problems also. I used lock tight to ensure the nuts do not back off. It is entirely possible the inner pivot shafts/cylinders/races are too short (I do not know what they are called). I will have to double check that next time I take the shock off. Link to comment Share on other sites More sharing options...
