Premium Member stealth09 Posted February 4, 2016 Premium Member Share Posted February 4, 2016 I am installing a ride-by-wire cruise control and would like to make as my wire connections as clean as possible. Specifically I'm needing the locations of the +brake light wire, clutch switch, throttle controls, and 12v power. Builderbob has already identified the speed control (VSS) and if necessary I can get the brake light signal and 12v under the seat, however I'd rather pull everything from the ecu harness. Thanks. Link to comment Share on other sites More sharing options...
