buckybuk Posted June 18, 2016 Share Posted June 18, 2016 I know this works on my bike. May or may not work on yours. My bike was flashed that may or may not matter. - turn the ignition key off and the engine run switch off - hold down the 'tcs' and 'reset' buttons - turn the ignition key on, keeping both buttons held down - after about 8 seconds, the display will change and say 'ecu' - press and hold down both buttons again display will change and say 'diag' - press and hold down both buttons again.....Walla your in the screen. You can use the "tcs" & "reset" buttons for up and down in the menu. Here you will need to know the "Diagnostic Code" & "Fault Code" (Your fault code is why your engine light is on to begin with) In my case the fault code was 024 (o2 sensor) The Diag code 63 displayed 024...... You then flip the engine run switch from off to on don't worry it won't start the bike it will just turn over I let it do it until the 024 disappeared to 0. Turned key off back on and wala no engine light.. I'm no rocket scientist but after not finding any info anywhere I did some digging and explained it the best I can. The whole purpose of resetting my light was testing if my o2 sensor was really bad..... Still working on that O_o 2016 R1 2015 FJ-09-------SOLD 2002 Wr250F 2014 Concours Link to comment Share on other sites More sharing options...
