Esperance Posted June 13, 2017 Share Posted June 13, 2017 Anyone know if there is aftermarket adapter to enable both headlights to be on when using low beam? Cant stand the 'one eye' look! You don't need an aftermarket adapter. Throw the switch on the left bar that turns on the high beam. All you then have to do is turn the vertical beam adjuster down quite a lot so the high beam points as low as the low beam. The light from the high beam is more centrally concentrated than the low beam but turning it down prevents it dazzling oncoming traffic. I have never been flashed by oncoming traffic with this arrangement and you are more visible to oncoming traffic. The only problem is that High beam for regular night driving won't be quickly available without readjusting. If you only drive in daylight though it might be the easiest solution. Link to comment Share on other sites More sharing options...
