Posted February 9, 20178 yr I received my phone mount from Hondo garage today. Looks amazing, holds extremely tight. It's ratchets as tight as you want. Has a button that allows for quick adjustments. Very well engineered and high level of finish. CNC machined aluminum. It solves the problem that I had with the ram mount where it squeezed the volume /power buttons. This also is available with ram ball.
February 9, 20178 yr Author The low profile bar clamp can be flipped in reverse if you need to clamp to something smaller than the handlebar.
February 13, 20178 yr Im having the exact same problem with it squeezing the power or volume buttons with the ram mount. So annoying. Going to have to check this mount out. Thanks!
