where I should connect aftermarket heated grip?
jonghoon
I read a ton of thread that say fj09 have 3 auxiliary socket back dash
but these connected to 2Amp fuse.
so if I connect this socket I should use relay.
I heard fz09 have 5amp heatwd grip socket.
but we dont have? oem heated grip is not my option. too high price
  • 1 month later...
I ran a fused 12 Volt line hot and ground from the battery to a relay and used the key switched on front 2amp aux to switch on the relay. The 3- 2amp aux outputs in the front are way too small in power to supply the grips, I believe they are for navigation , phones or GoPro type devices.  Going up in fuse rating size for them is not recommended it could cook your electrics. Kimofj
