howie333 Posted February 26, 2018 Share Posted February 26, 2018 '17 fj-09I'm installing a Back-off brake flasher and a Pro-oiler, and need to access the bikes speed sensor. I saw on another post the white/yellow wire at the ECU was tapped, but could there be a location closer to the battery compartment to be tapped ? If not I'm taping @ the ECU [span] [/span][span] [/span][span] [/span][span] [/span]I'm having trouble doing a search on this forum. I may be doing something wrong. [span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span][span] [/span] thanks; Howie... Link to comment Share on other sites More sharing options...
