geezer44 Posted October 11, 2018 Share Posted October 11, 2018 Any ideas on how to extend the brake peddle (not length but wider) so my foot does not slip off ? I thought about bending it but want to see if anyone has better idea!! Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted October 11, 2018 Premium Member Share Posted October 11, 2018 Easy peasy Cut a piece of aluminum the size of the pedal but another half inch wider made out of at least 040" thick aluminum Clamp it to the pedal and drill two 1/8" inch holes concentric through both about 3/8 to 1/2 an inch apart centered on the pedal Then pop rivet from the top the extension piece to the pedal you may want to consider putting washers on the other side of your holes are not tight Then get some peel and stick non-slip tread material preferably rubber-based used for stair nosing excetera and clean and stick it to the top surface of the pedal extension I've done this on a few bikes where I've added lowering kits You may need to lower the pedal slightly if you know how to do that to compensate for the thickness of the pedal extension I like my pedal a little lower anyway Link to comment Share on other sites More sharing options...
