brad27 Posted March 27, 2015 Share Posted March 27, 2015 http://www.aliexpress.com/item/2x-Universal-Motorcycle-Waterproof-12-LED-Turn-Signal-Light/1919367275.html Or these: http://www.aliexpress.com/item/Motorcycle-Amber-14-LED-Turn-Signal-Light-Indicator-Blinker-Flashers-For-Yamaha-Honda-Suzuki-Kawasaki-Ducati/32219347533.html Been waiting for my Fj for 2 months now. So i can't tell. Thanks! Link to comment Share on other sites More sharing options...
vango Posted April 11, 2015 Share Posted April 11, 2015 I think they will. You will need adapter plates for any aftermarket lights. Company's like rizoma sell five different yamaha adapters because the stock outline on the body work is tear drop shaped. Rizoma also sells wire adapters because every bike brand uses a different wire connecter. You could just cut them off and use a butt connecter. But I noticed one of the rear indicator wires on my fj is buried under a bracket. It's easy enough to unplug and reconnect but if you cut it off it may be difficult to re connect a spade or butt connector. It's probably a good idea to buy a set of wire adapters so you can leave the stock connectors intact. Link to comment Share on other sites More sharing options...
Order66 Posted April 12, 2015 Share Posted April 12, 2015 Or just cut them downstream from the connectors. Might need to anyway if you have to do resistors, which I'm guessing at $3.88/pair you'll probably need to add on. s e t h 2015 FJ-09 (The Me Bike) - CalSci, RAM, Shad, Givi, CrampBuster, Grip Puppies, GoPro, my custom Garage Door Opener Mod 2014 Valkyrie (The We Bike) - Too much to list, and no one on this forum cares anyway Link to comment Share on other sites More sharing options...
