WastedMind3500 Posted April 16, 2021 Share Posted April 16, 2021 I want to share some details on installing Barkbusters on a Tracer 900 2019. The instructions say you should reuse the M8 Washer from the original handguards. I never found that washer... The left one was easy to install, nothing to do besides follow the instructions. The right one is a bit trickier: you have to remove the brake master cylinder assembly. then install the Barkbuster support. and reattach the assembly. another critical point, if the support is installed too high (or rotated up to much), it will interfere with the brake lever. So make sure you leave enough space for the brake to operate properly, by rotating it down. Link to comment Share on other sites More sharing options...
draco_1967 Posted April 16, 2021 Share Posted April 16, 2021 I just installed mine today as well. I think the washer is for pre-2019 models. I didn't have to remove the brake reservoir assembly, but I loosened it up. Link to comment Share on other sites More sharing options...
