TaylWind Posted October 20, 2022 Share Posted October 20, 2022 Does anyone know if a jumper wire can be used with the diagnostic tool coupler to activate the ABS hydraulic pump after flushing the front and rear brake lines? Link to comment Share on other sites More sharing options...
skipperT Posted October 21, 2022 Share Posted October 21, 2022 I believe so but would have to consult the Service manual to be sure. I am aware that Yamaha uses a different connector for the ABS, however. You’ll need to locate that connector instead of the 4P one which is stashed under the seat bracket. -Skip Link to comment Share on other sites More sharing options...
