Grease monkey Posted October 27, 2023 Share Posted October 27, 2023 (edited) My battery is finished after two years of ownership. After pulling out the battery I find that the negative terminal on the battery which is nearest the tank is connected to the positive cable , and the positive cable furthest from the tank is connected to the negative cable!? How has the bike been running? How has the battery been charging for two years? Can this cause damage? TIA for advice Edited October 27, 2023 by Grease monkey Link to comment Share on other sites More sharing options...
Supporting Member betoney Posted October 27, 2023 Supporting Member Share Posted October 27, 2023 Are you absolutely sure that the battery came out of the bike in that orientation and didn't get flipped around? I say that because if you rotate the battery 180 degrees and then lay it over on its right side, the battery terminals will then be in the correct orientation with positive on top. There have been many post of owners here and on the FZ/MT09 forum getting it backward and bike always blows a main fuse if the terminals are reversed. 3 ***2015 Candy Red FJ-09*** Link to comment Share on other sites More sharing options...
Grease monkey Posted October 27, 2023 Author Share Posted October 27, 2023 Eish, you are right! Thanks! Thought I had someone swap out my battery at a shop or something 1 Link to comment Share on other sites More sharing options...
