Guest lawrenceofsuburbia Posted May 9, 2015 Share Posted May 9, 2015 About to order a pair of these, to complement (in a safety sense) the SKENE items at the rear. Is it necessary to use a relay with the Cree lights: if so, this electronologically-challenged member would appreciate advice on what type, how to wire-up through a handlebar switch,etc. Thanks in advance... Lawrence of Suburbia [em] (‘39 model) Brisbane Queensland Australia 2015 Matte Grey Tracer – now at 1647 km [/em] Link to comment Share on other sites More sharing options...
mjsracing Posted May 9, 2015 Share Posted May 9, 2015 No need for relay. The aux power leads are around 10A at 12V (120W). My Cree running lights are 20W total (1.7A). As long as you select a switch rated for 2A (or more) DC, you are fine. 2015 FJ-09, 2016 1290 Super Duke, 2017 150 XC-W (primary ride), 2012 DR650 Link to comment Share on other sites More sharing options...
vespadaddy Posted May 10, 2015 Share Posted May 10, 2015 How are you going to mount them? I think I am going to try and buy the Yamaha bracket. Link to comment Share on other sites More sharing options...
Guest lawrenceofsuburbia Posted May 10, 2015 Share Posted May 10, 2015 How are you going to mount them? I think I am going to try and buy the Yamaha bracket.Maybe on the side fairing that extends upwards and backwards from the headlight - it's a carbon-look element. Easy access there to bolt the bracket through and to thread the wires - nicely hidden - through and into the main body of the bike. Should be more effective there too, higher-up than my original thought of using the upper of the two bolts on the lower/ vertical part of the mudguard where it wraps in front of the bottom of the fork: that's possibly a bit too low to be fully effective in nose-to-tail traffic.. Will keep studying it though... L of S Link to comment Share on other sites More sharing options...
