hank362 Posted May 17, 2015 Share Posted May 17, 2015 I am installing frame sliders. I need to know the torque specs for the frame motor mounts. I would like to install a K/N air filter, any info would help a lot. Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted May 17, 2015 Premium Member Share Posted May 17, 2015 I am installing frame sliders. I need to know the torque specs for the frame motor mounts. I would like to install a K/N air filter, any info would help a lot.Always check out the how to section: linky Or: Engine mount bolts, 33 lb ft (45 Nm) (Used to mount frame sliders) A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
vespadaddy Posted May 17, 2015 Share Posted May 17, 2015 FWIW, I have read that both the Hi flow Yamaha filter and the K&N both fail to show any power increase on the dyno over the OEM filter. Link to comment Share on other sites More sharing options...
hank362 Posted May 19, 2015 Author Share Posted May 19, 2015 Thank you for the specs. It will put to good use, thanks again. Link to comment Share on other sites More sharing options...
