madsquabbles Posted June 25, 2016 Share Posted June 25, 2016 T- minus 2 weeks until cross country adventure on the fj. Running a gps that will be powered from a battery tender lead to 12v plug adapter. Any reason why I shouldn't run it that way? Also for those who have blown fuses in the stock 12v plug what else will stop working if that one blows? I am running gps from battery tender lead from battery but will considering occasional use of stock 12v for phone charge. Link to comment Share on other sites More sharing options...
parablob Posted June 25, 2016 Share Posted June 25, 2016 Hi the two amp fuse only covers that outlet and no other system will be affected , I upped the fuse rating to 3.5 amp as I had my tom tom on that outlet and for some reason blew twice , I had the system checked over and no fault found and since I upped the fuse I have had now other issues in 6000 miles , taking power straight off the battery is fine until you forget to unplug or swith off , don't forget you have the wiring on the other side which is used for the second power outlet as a accessories socket, this is ignition dependent Hope this helps Link to comment Share on other sites More sharing options...
madsquabbles Posted June 25, 2016 Author Share Posted June 25, 2016 Thanks for the response. Maybe I should also look into the "off" side. Guess I should research that as I am not familiar with it. Link to comment Share on other sites More sharing options...
Premium Member wessie Posted July 3, 2016 Premium Member Share Posted July 3, 2016 I run my Garmin Zumo and 0.5A USB phone charger through the standard outlet - the phone charger unit has a pass through socket to take the Zumo cradle's plug. No problems with the fuse blowing. This signature is left blank as the poster writes enough pretentious bollocks as it is. Link to comment Share on other sites More sharing options...
