skydvrd Posted July 21, 2016 Share Posted July 21, 2016 My 2015 FJ had what appeared to be a traction control issues the other day. Pulling off at low speed, TCS engaged, chopping the throttle. The ABS light came on and left me with no front brake. Shut off and tried again, no change. Disabled TCS and rode home no problem. Next morning, same thing except I had code 069 on the display. Thanks to the forum, I discovered that's a front speed sensor issue. Found a post with pictures of the sensor (thanks again forum) and went to have a look. Removed sensor from housing, removed some debris from the end and wiped off the disk. Replaced everything and started up. No more TCS issues, all warning lights off, code cleared! Cancelled appointment with service department. Anyone else experience this? Link to comment Share on other sites More sharing options...
duhs10 Posted July 21, 2016 Share Posted July 21, 2016 My 2015 FJ had what appeared to be a traction control issues the other day. Pulling off at low speed, TCS engaged, chopping the throttle. The ABS light came on and left me with no front brake. Shut off and tried again, no change. Disabled TCS and rode home no problem. Next morning, same thing except I had code 069 on the display. Thanks to the forum, I discovered that's a front speed sensor issue. Found a post with pictures of the sensor (thanks again forum) and went to have a look. Removed sensor from housing, removed some debris from the end and wiped off the disk. Replaced everything and started up. No more TCS issues, all warning lights off, code cleared! Cancelled appointment with service department. Anyone else experience this? the very first time I rode the bike after bringing it home I got that code. I found that the dealer had not installed the ABS sensor correctly (there was an extra spacer) so the bike wasn't detecting the movement of the front wheel. Took the spacer out and have never had a problem since. '15 FJ-09 w/ lots of extras... Fayetteville, GA, USA Link to comment Share on other sites More sharing options...
skipperT Posted July 21, 2016 Share Posted July 21, 2016 Part of dealer assy. These bikes are shipped with the front wheel removed. So anytime there's work done on either front or rear tire - or they are removed for other work, the abs sensors might be removed. Skip Link to comment Share on other sites More sharing options...
Premium Member fanowater Posted March 31, 2017 Premium Member Share Posted March 31, 2017 So i just had this exact issue. Somehow the bracket on the front ABS sensor got slightly bent and was too far away from the rotor. Pounded the bracket flat and all was well. I want to give a huge shout of thanks to Skydvrd for posting this. I thought I was having some weird fueling issue. This was much easier to fix. Cheers, Happy FJ owner 2015 FJ-09 2006 Triumph Daytona 675 Link to comment Share on other sites More sharing options...
Premium Member jeff400650 Posted April 17, 2017 Premium Member Share Posted April 17, 2017 Mine had the front sensor issue as they tried to deliver it to me off the showroom floor. Pistons or pedals, 2 wheels are where it's at... Link to comment Share on other sites More sharing options...
