berryber Posted August 8, 2016 Share Posted August 8, 2016 I had some ABS plastic left over from some pistol cases I customized. Thought I'd see if I could move this from the right accessory outlet mount. To a spot that would be easier to see. It's been raining everyday for the last couple of weeks and when i pulled it out to move it. It was full of water. I drilled a drain hole in the bottom and sprayed some stuff I've had for years inside. Its called Chemsearch NC123 Plus and it leaves a non conductive coating. Might not have needed it since the thing was working while full of water. Link to comment Share on other sites More sharing options...
Premium Member DavidS Posted August 9, 2016 Premium Member Share Posted August 9, 2016 I like that a lot, very clean install Link to comment Share on other sites More sharing options...
