Posted December 26, 20168 yr Bright sunny day...the bike just out of its 600 mile service...and a great ride in prospect...until fluid starts coming out of the rad and clouds of steam appear. Never had a radiator go on me before, so bearing in mind its only got 600 miles on it, a question guys: Do I try to seal it with 'Radweld', or is it back to the shop for a replacement? Thanks Phil
December 26, 20168 yr Bright sunny day...the bike just out of its 600 mile service...and a great ride in prospect...until fluid starts coming out of the rad and clouds of steam appear. Never had a radiator go on me before, so bearing in mind its only got 600 miles on it, a question guys: Do I try to seal it with 'Radweld', or is it back to the shop for a replacement? Thanks Phil Unless a rock or anything else was kicked up and punctured it, it's a warranty replacement. No question, do that! Piedmont of NC '15 FJ-09 '94 GTS-1000
December 26, 20168 yr Bright sunny day...the bike just out of its 600 mile service...and a great ride in prospect...until fluid starts coming out of the rad and clouds of steam appear. Never had a radiator go on me before, so bearing in mind its only got 600 miles on it, a question guys: Do I try to seal it with 'Radweld', or is it back to the shop for a replacement? Thanks Phil Definitely not a common problem. I would do a quick look to see what they might have mucked up at the 600 mile service (loose connectors, radiator cap, etc) then take it back. A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!)
December 26, 20168 yr Bright sunny day...the bike just out of its 600 mile service...and a great ride in prospect...until fluid starts coming out of the rad and clouds of steam appear. Never had a radiator go on me before, so bearing in mind its only got 600 miles on it, a question guys: Do I try to seal it with 'Radweld', or is it back to the shop for a replacement? Thanks Phil yeah, straight back to the shop.....if by chance it is road damage, K Seal is much better than radweld...(if you have to do a temp repair)
December 27, 20168 yr If this is really "Right after your 600 mile service" I'm wondering if they did something that caused this? Maybe poked the radiator by accident? If you have been riding a bit since the service, than maybe not, just bad luck!
December 27, 20168 yr Author Thanks for the advice guys. The bike hadn't moved since i parked it up after riding back from the service. The more I think about it the more it looks like a warranty issue. Always nice to have your opinions. Phil
