dan77 Posted January 4, 2017 Share Posted January 4, 2017 Hi, the new 2017 FJ09 has possibility to install a new Quick Shift System as accessory. "Ready to Accessorize The 2017 FJ-09 is ready for a range of Genuine Yamaha accessories, including windscreens, luggage and more. Performance-minded riders can also install a new Quick Shift System to unlock clutchless full-throttle upshifts for even sportier performance." Has anyone fitted this Quick Shift System in a new 2017 or if is possible in a 2015 or 2016 unit? many thanks. Link to comment Share on other sites More sharing options...
norcal616 Posted January 4, 2017 Share Posted January 4, 2017 Im in love with my Woolich QS choice... Looking into the OP question i dont see the Yamaha QS yet on the interweb... I suspect its just the same thing as the QS by Annitori Racing(vast majority of QS are used this way) i use on my FZ-07 which has piggy back connectors to attach to the coil pack on each spark plug which requires no ECU modification to work...the Woolich QS i use has to be set up thru the ECU to work since it uses the stock O2 connector and wiring to work(o2 sensor is disabled thru Woolich software)... As for the QS offered by Yamaha i dunno if it will work with older FJ-09 yet, we need more information to work off of, is it special in a certain way? Where is it connected to, pictures of wire length, etc are the wire OEM looms the same for older years??, etc Dynojet and Healtech are 2 other excellent QS platform that require no ECU reflash...you can also get a QS thru Flashtune which 2wdw can set up for you as it requires an ECU flash... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
yamahafjrider Posted February 12, 2017 Share Posted February 12, 2017 I use the Flash Tune quick shift. I installed it last spring. It requires their flash, kit, rods and switch. It uses the tip over sensor to interrupt the spark. You need to be over 4,000 RPM for it to work. It provides a smooth shift and I find myself using it often, not just during hard acceleration. Kurt Link to comment Share on other sites More sharing options...
dan77 Posted August 23, 2017 Author Share Posted August 23, 2017 Has anyone fitted genunine Yamaha Quick Shift System in a 2015 or 2016 unit? Link to comment Share on other sites More sharing options...
norcal616 Posted August 23, 2017 Share Posted August 23, 2017 https://www.shopyamaha.com/product/details/fz-09-gytr-quick-shifter-kit this? the 2017 bikes have a different ECU bin file than the pre-2017 bikes so its very likely the pre-2017 bikes do not have the ECU set up for the QS or the 2017 bikes have an extra connection built into the wiring harness that the pre-2017 bikes do not... 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
dan77 Posted August 23, 2017 Author Share Posted August 23, 2017 https://www.shopyamaha.com/product/details/fz-09-gytr-quick-shifter-kit this? the 2017 bikes have a different ECU bin file than the pre-2017 bikes so its very likely the pre-2017 bikes do not have the ECU set up for the QS or the 2017 bikes have an extra connection built into the wiring harness that the pre-2017 bikes do not... Yes, that quick shifter kit. I know these differences, but I think that probably someone, with a pre-2017 model, has added a wire from the ECU to the qc and he has changed some setting in the ECU to activate it. Link to comment Share on other sites More sharing options...
norcal616 Posted August 23, 2017 Share Posted August 23, 2017 many other QS options available on the market that are already plug and play that work with both up and down shifts or GP style shifting not just upshifts like the Yamaha one... any reason why you want to use this QS? This QS is gonna cost you more to get started(I am assuming you dont have any software to read/write an ECU) 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
dan77 Posted August 25, 2017 Author Share Posted August 25, 2017 many other QS options available on the market that are already plug and play that work with both up and down shifts or GP style shifting not just upshifts like the Yamaha one... any reason why you want to use this QS? This QS is gonna cost you more to get started(I am assuming you dont have any software to read/write an ECU) Hi norcal616, no any reason, just because I think that maybe the Yamaha QS could be more simple installation than others. Link to comment Share on other sites More sharing options...
norcal616 Posted August 25, 2017 Share Posted August 25, 2017 many other QS options available on the market that are already plug and play that work with both up and down shifts or GP style shifting not just upshifts like the Yamaha one... any reason why you want to use this QS? This QS is gonna cost you more to get started(I am assuming you dont have any software to read/write an ECU) Hi norcal616, no any reason, just because I think that maybe the Yamaha QS could be more simple installation than others. The simplest one to install and set up/fine tune, like without having to set the "kill times" is the one by FlashTune in which 2WDW can set up your ECU if you already got your ECU reflashed from them? Or send FlashTune your ECU to activate the QS Cleanest looking one is by Healtech 2012 wr250f - C-class 30+ age group 2015 fz-07- Hordpower Edition-80whp 2015 fj-09- Graves Exhaust w/Woolich tune by 2WDW @120whp Link to comment Share on other sites More sharing options...
badballie Posted March 17, 2018 Share Posted March 17, 2018 Just a heads up Webike has the quick shifter an sale at 150$ which is a good price (OEM). I have fitted one to my 17 tracer and it works very well over about 3000 RPM, below that it is a bit clunky but it works on the 17 and fitting is simple . https://japan.webike.net/products/23435285.html Link to comment Share on other sites More sharing options...
richarddacat Posted May 22, 2018 Share Posted May 22, 2018 Bumping out of curiosity. Exactly what does the QS do? Are you still using the clutch when shifting or does the QS eliminates its use above a certain rpm? Thx Link to comment Share on other sites More sharing options...
crazyivan Posted May 22, 2018 Share Posted May 22, 2018 This was posted just a few days ago: [video src=https://youtu.be/mlBhPZdVqb8] This guy shows installing a Yamaha quickshifter on an R6, and then takes it out for a ride: [video src=https://youtu.be/3wAvbQ_5dU8] Link to comment Share on other sites More sharing options...
whiskydave Posted June 10, 2018 Share Posted June 10, 2018 Test rode the new Tracer GT with the quick shifter. What a great piece of kit. Seriously thinking of buying one for my 2017 model Link to comment Share on other sites More sharing options...
madsquabbles Posted June 11, 2018 Share Posted June 11, 2018 Test rode the new Tracer GT with the quick shifter. What a great piece of kit. Seriously thinking of buying one for my 2017 modelWhere are you located? I thought new GT was not out yet but was incoming. Link to comment Share on other sites More sharing options...
rockafella50 Posted June 12, 2018 Share Posted June 12, 2018 Test rode the new Tracer GT with the quick shifter. What a great piece of kit. Seriously thinking of buying one for my 2017 model I have one on my 2017 model. Works decent. Link to comment Share on other sites More sharing options...
