chamelion Posted April 4, 2017 Share Posted April 4, 2017 https://www.omniaracing.net/tech-cartuccia-forcella-regolabile-20ids-20mm-per-yamaha-mt09-2014-p-39792.html https://www.omniaracing.net/kit-cartuccia-idraulica-regolabile-andreani-per-forcella-yamaha-tracer-20142015-p-21636.html I cannot for the life of me decide between the two. Does anyone know if the K-Tech cartridge DOESN'T have the same hydro locking issues as the Andreani? I'm getting the K-Tech razor R shock, so I'd like a matched set, but if the Andreani is just as good then I may as well get that and then purchase the upgrade kit for it for about the same over all money. Cheers. Link to comment Share on other sites More sharing options...
chamelion Posted April 4, 2017 Author Share Posted April 4, 2017 Went with the matching k-tech shock and cartridges. Link to comment Share on other sites More sharing options...
kimofj Posted April 7, 2017 Share Posted April 7, 2017 I just went with KTech and YA335 ohlins really great combo for not so much $. Jim in Ojai ca Link to comment Share on other sites More sharing options...
bonoeuf Posted June 3, 2018 Share Posted June 3, 2018 What are the hydraulic loking issues you mention? Link to comment Share on other sites More sharing options...
pattonme Posted June 4, 2018 Share Posted June 4, 2018 What are the hydraulic loking issues you mention?The Andreani with my fixes works good. The IDS20 with a thin oil in the Comp leg works well enough. Ditto NIX30 The Andreani valving simply can't move oil fast enough to properly absorb bumps. If you Google the problem exists across their entire product line. If you're in the USA please do not use Omnia. You will be gray-market importing them and will not have the support of Andreani USA. The K-Tech IDS is distinctly better than the Andreani in every other way as it relates to materials and fit and finish, leaving aside the damping... Link to comment Share on other sites More sharing options...
