Posted April 6, 20178 yr Guys for budget reasons I bought a OHLINS standard YA335 for my FJ09 along with a K-Tec forks cartridges. After gong through the PIA shock install I realized that the Compression Adjustment Screw is way up at the top of the shock and almost impossible to get to with my fingers let alone a 90° screwdriver. I have about 1/2 an inch clearance to get to the screw which pointing up toward the gas tank. I thought of turning the shock 180° to point the screw down but that doesn't seem any easier to get to with tubes and other crap in the way. Does anyone have any ideas? I guess I should have paid the $500 more for remote adjustment. Thoughts. Jim in Ojai CA
April 6, 20178 yr Guys for budget reasons I bought a OHLINS standard YA335 for my FJ09 along with a K-Tec forks cartridges. After gong through the PIA shock install I realized that the Compression Adjustment Screw is way up at the top of the shock and almost impossible to get to with my fingers let alone a 90° screwdriver. I have about 1/2 an inch clearance to get to the screw which pointing up toward the gas tank. I thought of turning the shock 180° to point the screw down but that doesn't seem any easier to get to with tubes and other crap in the way. Does anyone have any ideas? I guess I should have paid the $500 more for remote adjustment. Thoughts. Jim in Ojai CA Sorry to disappoint Jim, but the YA335 does not have compression adjustment; only rebound and manual preload. The screw head you're trying to reach is not for consumers, that's the nitrogen fill port. Don't mess with it. The YA535 has hose-mounted compression adjustment, rebound adj, and hydraulic preload. Keep Asheville weird!
April 6, 20178 yr Author BentAero: Well that answers that, one more thing I don't have to adjust. Thanks for getting back so quickly. Jim
