agunslinger Posted September 10, 2017 Share Posted September 10, 2017 Keep seeing different specs for these bolts. Some say 16 fp all around, some say 16 upper, 29 lower. Anyone have the service manual? And to fasten correctly, tighten uppers down until no gap, then lowers down where there will be gap, correct? thx Link to comment Share on other sites More sharing options...
Premium Member ULEWZ Posted September 10, 2017 Premium Member Share Posted September 10, 2017 Straight out of the manual, 16u/29L. linky A government which robs Peter to pay Paul can always depend on the support of Paul. George Bernard Shaw (1856-1950) Bikes: 2015 FJ-09, Seat Concepts seat cover and foam, Cal Sci medium screen, rim stripes, factory heated grips, Cortech Dryver tank bag ring, Modified stock exhaust, FlashTune with Graves fuel map, Cree driving lights, Aux power socket. 2012 Street Triple type R (Wifes) 2007 FJR1300 (Sold!) Link to comment Share on other sites More sharing options...
Supporting Member texscottyd Posted September 11, 2017 Supporting Member Share Posted September 11, 2017 I think there may be some confusion here on 'upper' and 'lower' in this context. I believe that 'upper' refers to the four hex head bolts that secure the caps to the risers and clamp the handlebars in place, while the 'lower' is the spec for the nuts under the triple clamp that threads onto the riser studs and - recall notwithstanding - secures the risers to the upper triple clamp from below. Link to comment Share on other sites More sharing options...
Guest kernowjim Posted September 11, 2017 Share Posted September 11, 2017 the workshop manual states: "First, tighten the bolts on the front side of the upper handlebar holder, and then on the rear side." So this means tighten the forward bolts down to it stops (16 ft lbs) and then the rearward (closest to you) to 16 ft lbs - there will be a gap. This is how they are from new. Link to comment Share on other sites More sharing options...
agunslinger Posted September 12, 2017 Author Share Posted September 12, 2017 Thanks gentlemen. That makes sense and explains the other 29 torque posts. I HOPE they understood that distinction. Link to comment Share on other sites More sharing options...
