madeuce216 Posted December 9, 2017 Share Posted December 9, 2017 I have a set of fjr bags keyed to my ignition key. Can the same be done with my shad top case? The key for that is substantially different in size. Anyone done this?? Link to comment Share on other sites More sharing options...
Premium Member 2and3cylinders Posted December 10, 2017 Premium Member Share Posted December 10, 2017 No but my 2 Shad SH 36 side cases and SH46 top case are keyed alike, which in a weird way I actually like because I keep the Shad key and my disc lock key on a separate fob, and can keep the ignition key in the ignition or pop the saddle and can at the same time mess with the luggage. Becomes second nature after a while... But a good locksmith should be able to make it happen four you. BTW, the Shad side cases are not only larger than the Yamaha OEM (that I believe are private labeled for Yamaha by Shad) but the Shad are lighter and their mounting system while maybe not as tight to the bike are far stronger and much more secure and quicker to use. Link to comment Share on other sites More sharing options...
