Ultimateaddons Phone Case
I have purchased and fitted an Ultimateaddons Phone Case for my iPhone 6 Plus which will be performing satnav duties.  It's mounted to the Cosmo GPS mount which sits behind the windscreen.  The case allows for a waterproof connection of the charging cable.  This will plug into the double USB socket I have fitted in the right hand side of the dash.  The USB socket is hard wired to the black accessory socket behind the dash.  Looks pretty good I think.
It has a quick release so I can just remove it as and when I want.
CS
I have one of those cases for my Samsung S6 and put it on a RAM ball on one of the riser bolts. They’re brilliant cases and I even use the case when backpacking as it is waterproof and shockproof.
